I-Series storage board & boot problem.
  • Albonline
    • Sep 2008
    • 1153
    #31
    the ones that got hot always failed at a later time. replace it.
    • aberock
      • May 2022
      • 127
      #32
      i tried to clone the whole disk with functional one but when try to load firmware MFP CONTROLLER NG.
      any solution for this so that we can save the i series ? lol
      • stronghold
        • Apr 2023
        • 47
        #33
        In your case, for more detailed diagnostics, you need to use 'The Diagnosis and Recovery Tool for Bootup Issues.' Below, Iโ€™ve attached a document describing this procedure:
        PRI_DLKM_BT2021021EN_09.pdf
        • aberock
          • May 2022
          • 127
          #34
          Hi sir ,
          can i get a copy of the tools for C250i and C450i ?
          Thanks.
          • CP-1015
            • Nov 2020
            • 323
            #35
            Can anybody give me AA2J0Y0-F000-GXX-28.exe and Data_Recovery_Procedure.xlsx? Because the next defekt C-250i is comming? Thanks!
            • tsbservice
              Field tech
              • 8035
              #36
              PM me.
              • CP-1015
                • Nov 2020
                • 323
                #37
                PM me.
                Thank you very much!
                • aberock
                  • May 2022
                  • 127
                  #38
                  PM me.
                  sent you pm sir
                  • CP-1015
                    • Nov 2020
                    • 323
                    #39
                    How can i delete partitions on SSD?
                    I tried with diskpart. But it isn't possible to show partition with list partition. Clean all istn't possible, too.
                    • plus-COPY
                      • Aug 2023
                      • 32
                      #40
                      Probably the SSD on which you cannot delete the partition is locked against writing.
                      You can unlock it on a computer that supports SSD with the same encryption as in the Bizhub "i" series device.
                      The unlocking procedure is described but I would advise against using this solution, you never know if the repaired SSD will be fully functional.
                      If you need replacement SDD at a "normal" price, write to me.
                      Best regards
                      • CP-1015
                        • Nov 2020
                        • 323
                        #41
                        Best regards
                        Yes, of course, it's locked. Where is the unlocking procedure described? I tried with disk management and with disk part without success. Thanks advanced.
                        PS.: According to diskpart it's not locked.
                        • stronghold
                          • Apr 2023
                          • 47
                          #42
                          If you read the document carefully, everything is described there. When you upload the service firmware GXX- and complete step 4, you will see this screen with two options: A and B.
                          Option A removes the encryption key.
                          image.pngโ€‹
                          • CP-1015
                            • Nov 2020
                            • 323
                            #43
                            Thanks I've got it.
                            • CP-1015
                              • Nov 2020
                              • 323
                              #44
                              After new SSD (not Minolta, reset old SSD, I'll try later), it boots to 50% instead of 25%:
                              SD recoginiton: ng
                              Replace [SSD/uSD], and if the problem persits, replace [CPU board].
                              Any other chance instead of CPU?
                              Thanks advanced.
                              • aberock
                                • May 2022
                                • 127
                                #45
                                SD recoginiton: ng
                                Thanks advanced.
                                what's the sympton of the ssd locked ?
                                i got few piece in diskpart listed 0GB available . This consider locked or crapped ? lol
