I-Series storage board & boot problem.
  • avecosat
    • Jun 2012
    • 305
    #16
    Re: I-Series storage board & boot problem.
    Where can I get the utility testdrive ?
    Thanks in advance
    • copier tech
      • 8172
      #17
      Originally posted by Albonline
      I've done over 20 of them using a m2 ssd adaptor and a utility called testdrive. remove all partitions and leave the drive raw and unformatted. looks just like a new drive to copier. (bad ssd's will preform sluggish and get hot while being wiped i toss these )
      Does this wipe the machine counters etc? if so is there away to back them up first?
      • adecanmin
        • Oct 2010
        • 316
        #18
        Which m2 ssd adapter does one need to buy? Looked for testdrive could not find it on the internet.
        • adecanmin
          • Oct 2010
          • 316
          #19
          I'm guessing I will need to purchase a m.2 nvme ssd to usb 3.1 pci-e to usb-a 3.0 internal converter card
          • Albonline
            • Sep 2008
            • 1151
            #20
            Thanks in advance
            misstated utility is testdisk for windows.
            • Albonline
              • Sep 2008
              • 1151
              #21
              here is what i use
              ORICO Transparent NVMe M.2 Enclosure Tool-Free USB3.1 Type-C Gen2 10Gbps to M.2 SSD
              • Albonline
                • Sep 2008
                • 1151
                #22
                counters should be recovered while system restores itself, life stats are stored on a separate chip/board.
                • Max
                  • Oct 2011
                  • 561
                  #23
                  In my experience. It wipes the whole lot.
                  • Albonline
                    • Sep 2008
                    • 1151
                    #24
                    if you change more than just ssd. yes all is destroyed. If you attempt a unwiped used drive. counter info could be scrambled . if you try any used uncleared board in the i series results are always bad.
                    • adecanmin
                      • Oct 2010
                      • 316
                      #25
                      here is what i use
                      • occus
                        • 337
                        #26
                        I didn't quite understand whether you formatted the old storage board or used a new one.
                        If you are using a new one, I wonder if it has to be a certain type.
                        Thank you for feedback.
                        • Albonline
                          • Sep 2008
                          • 1151
                          #27
                          both, however the new ones i have are from new damaged km stock and have to be formatted. There is an in machine way of doing the same thing but it requires a password code number to execute.
                          • CP-1015
                            • Nov 2020
                            • 323
                            #28
                            Another C-250i (D-Color 259MF):
                            - Data only 25%
                            - Diagnoses with displayswitch: light purple, data 25% and nothing else
                            - connecting Storage board with PC: It aks wether MBR or GPT (Storage board getting hot)
                            - After MBR (ok?) reconnecting with device and starting with USB: dot ok, data 25%
                            Does a new storage board make sense or did I need recovery software?
                            Thanks!
                            • Albonline
                              • Sep 2008
                              • 1151
                              #29
                              i always left them with no format at all, raw. the best clue you gave was its getting hot. how hot? if its burn your fingers hot ,toss it.
                              • CP-1015
                                • Nov 2020
                                • 323
                                #30
                                I didn't format it. I don't think burning fingers. But without success. What shall I do?
