Stuck on bars
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    [Dead] Stuck on bars
    Hi guys, I have a Bizhub 4050 that gets stuck on the bars after powering it on. The engine runs before, but the panel still shows the bars. is there any recovery tool or FW for it?
    Thanks.
    Field technician since 1994
  • copier tech
    • 8200
    Re: Stuck on bars
    Thanks.
    Start by updating the regular firmware before you start replacing boards etc.
    • elmaligno
      • Oct 2009
      • 302
      Re: Stuck on bars
      I think it's great that you try to sell your crap here, but this is a serious site and I am a technician with 30 years of experience that does not need to come with nonsense like that. This machine does not support firmware upgrade without booting, which does not happen, and that is the reason for my question.
      • copier tech
        • 8200
        Re: Stuck on bars
        For someone so experienced you should know about the recovery firmware!
        • elmaligno
          • Oct 2009
          • 302
          Re: Stuck on bars
          I was expecting a comment like that, which shows you don't know what you are talking about, as these machines are Lexmark based and cannot be booted with firmware from the usb.
          If you are so smart and you have the firmware you seem to be talking about, show it to us!
          • tsbservice
            Field tech
            • 8052
            Re: Stuck on bars
            Try to unplug HDD and see it will get past boot screen and error out.
            • elmaligno
              • Oct 2009
              • 302
              Re: Stuck on bars
              Thanks a lot, but as I said, I did that and disconnected fax too.
              • Gift
                • Mar 2011
                • 2459
                Re: Stuck on bars
                Is it possible to access the web interface?
                • elmaligno
                  • Oct 2009
                  • 302
                  Re: Stuck on bars
                  no, it is not possible
                  • Gift
                    • Mar 2011
                    • 2459
                    Re: Stuck on bars
                    In this case you might have a faulty controllerboard or nvram/ssd (in case that's a discrete part on this crap lexmark board).
                    I couldn't see any recovery tools in knova. You might be able to fix it with a parts donator, otherwise I'd probably just forward it to the sales guys before ordering any
                    stuff based on guessworks. I sure guess the prices for these "Bizmark" PCBs are probably ridiculously high.
                    • elmaligno
                      • Oct 2009
                      • 302
                      Re: Stuck on bars
                      I'm afraid that's what happens, that's why I was asking if anyone knew anything else, since the C3350s have the same software and there is a boot firmware for them.
                      • strider5555
                        • Jun 2008
                        • 96
                        Re: Stuck on bars
                        You can try booting up the machine into extra service mode by holding the sub power switch on the panel while turning on the main switch. If it boots to the CE password screen, you may be able to flash with the latest base firmware, and also possibly format the HDD. Also if you haven't already, make sure the network cable is disconnected.
                        • tsbservice
                          Field tech
                          • 8052
                          Just had one with same problem. Extra service mode can't be reached. Put another HDD from working machine and can enter extra service mode where format of HDD was made. All good then.
                          Failed HDD was cleared in PC and put in another working machine then we enter extra service mode and did format which took many more time to complete than working HDD. Eventually it finishes at 100%.
                          Upon restart previously working machine stuck at 5 bars and KM logo.
                          Conclusion - replace HDD.
