C450i error j99-01
KM C450i
Tags: None
C450i error j99-01Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
If I helped you out, please give me a thumbs up! It helps my reputation. -
C450i error j99-01
JAM type Controller JAM (paper size error (paper length)) JAM code 99-01 JAM detection timing 99-01 - As a result of a paper size error (paper length), the controller transmits a forced stop command to the printer engine and the printer engine is internally processing the size error.
- As a result of a paper size error (paper length), the controller transmits a forced stop command to the printer engine; but the paper causing the size error cannot be fed out.
I had the same error on a c658 last week. Turned out to be a dirty laser, I just used the grey cleaning arm with the white cleaning pad to clean each laser glass, after cleaning all the lasers the machine worked perfectly fine again.Comment
FS539 fittedField technician since 1994Comment
