Is there anyway to manually reset c3350/51 imaging unit levels
  • HarryBurgess
    • Oct 2019
    • 25
    Hi, just a quick one. When you ever get the error that states there's a too high toner density e.g. 2558, is there any way to manually reset these levels? Without having to either put a reset chip on, get a new imaging unit or even just printing and stabilising until it balances back out?
    Not sure if I've phrased this in the best way but any help is appreciated thanks.
  • rrrohan
    • Sep 2011
    • 1977
    if it says its to high its to high. spamming some 100% coverage prints is still your best option before trying new parts
    • kingarthur
      • 1350
      Every time I've had it, I've just printed off black test prints until the level drops - works 95% of the time
      • Woxner
        • Jul 2011
        • 848
        Use RB firmware. It's supposed to help and I think it ignores the ratio and won't code
        • azzajil
          • 12
          How to get RB firmware?
          • tsbservice
            Field tech
            • 8007
            I think you guys mixed models. It's not i series but previous.
            • Wow_copier
              • Feb 2020
              • 6
              I had this code come up when you install some of the Chinese IU-Reset chips. Sometimes you install the chip & it resets the IU counter but codes out. Then you can turn off & install the old chip back in & the counter is reset & code goes away. I'm so sick of these dam Konica chips!!!
              So also can anyone tell m ehow to add the button in the Utilities to check the consumable life? By default on the c3351 there is no way to view the consumables & print a report on the screen. Is it a soft switch setting? Anybody know how?? Thanks
              • Ziggy
                • Feb 2018
                • 722
                Set Sw227 to hex 00 to be able to view the consumable levels .
                • tsbservice
                  Field tech
                  • 8007
                  According to manual C3350 may not have Sw227, C3351 have it.
