C224e airprint tab missing
  • copyman
    Owner / Technician
    • Sep 2005
    • 4732
    One of my customers asked if I could turn on airprint but when I went to turn on under network settings tab was missing. Is there a soft switch setting that needs to be changed?
    I usually turn this on with any machines I sell even though most customers don't use it. Just happens this customer wants to use it and first time I've never seen tab under network settings in admin mode?
    Thanks in advance
  • kingarthur
    • 1375
    Try this
    Please note - In order to activate Airprint, the device must have G20-J6 or later firmware installed, and the device must be set to "Function Version 7" or later. (Please see the firmware readme for instructions).
    Only "e" series devices are currently supported.
    If the setting for Airprint is not available in PSWC (Pagescope Web Connection) then please clear your Web Browser Cache
    Supported Apple devices to use AirPrint (iOS 4.2 or later /MacOS 10.7 or later):
    - iPad (all models)
    - iPhone (3GS or later)
    - iPod touch (3rd generation or later)
    Function Version 7 - New Features
    This is an overview about new functions and operability improvements which are available with G20-J6 firmware by changing Soft Switch 25 to HEX60. (Function Version 7)
    Please see attached.
    Amended to revise Airprint Dip SW setting
    • copier tech
      • 8188
      Thanks in advance
      As stated above update the firmware & function version then you'll have the Airprint option in admin settings.
      We can supply the firmware should you need it.
      www.printerfirmware.co.uk
      • copyman
        Owner / Technician
        • Sep 2005
        • 4732
        Hi, Thanks for offer but I have access to Kon/Min dealer website and download firmware & manuals for free.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4732
          Originally posted by kingarthur
          Try this
          - iPad (all models)
          Thanks for the reply. This machine has firmware G20-M1 so will try setting to Func 7 & also the soft switchs for airprint
          • copier tech
            • 8188
            No problem. My posts are often of use to members who don't have access to KM support.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4732
              And if those members are "supporters" of this website I will offer them manuals or F/W for free. I don't believe in selling material that I don't own. Especially when copyrighted and illegal to do so.
              • Duplicator
                • May 2022
                • 248
                Just a heads up. If you have any iOS 17 (or newer) clients trying to AirPrint to a 4e family copier, it will cause it to get stuck in multiple errors. Apple changed how AirPrint works in iOS17. We have been pushing all of our customers on older copiers to the Koncia Minolta app since it doesn't use AirPrint in any way.
                Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                If I helped you out, please give me a thumbs up! It helps my reputation.
