c458 intermittent c9401
  • adecanmin
    • Oct 2010
    • 298
    Gentlemen
    Anyone had this problem? I have the service manual. Could it be the cable? I searched and all I could find was a solution for an older Konica Minolta.
  • Ziggy
    • Feb 2018
    • 701
    I would try the cable to SSD first also
    • adecanmin
      • Oct 2010
      • 298
      OK
      • Ziggy
        • Feb 2018
        • 701
        Originally posted by adecanmin
        OK
        Sorry I meant to say the cable to the CCD . I have i-series on the brain haha
        • Thib
          • May 2017
          • 35
          I've seen this 4 times, 3 times it was the ribbon cable going from the scanner ctrl board to the lamp, 1 time it was the Scanner control board. If I remember correctly the board was not intermittent, it was constant.
          • Synthohol
            Certified Konica Expert
            • 5808
            thats always been a faulty dual scan board in the back for me.
            you can rule out the CCD by removing the dscb and setting ADF in service mode to none.
            you should be able to scan and copy normal without a code to verify its the dscb.
            good luck!!
            • adecanmin
              • Oct 2010
              • 298
