BIZHUB C224 missing "Store address" tab in the web interface
  • mandongo
    • Mar 2021
    • 32
    Please, tell me how to resolve this.
    Thanks in advance!
  • progoffice
    • Nov 2008
    • 337
    Re: BIZHUB C224 missing "Store address" tab in the web interface
    Log in as administrator. This has probably been disabled under the "Restrict User Access" within the "Security" tab. Either way, you'll need to login as an administrator to add your scan one touch or edit the security settings so it can be done as a public user.
    • tsbservice
      Field tech
      • 8081
      Store address should be available from user settings by default.
      • Synthohol
        Certified Konica Expert
        • 5922
        is the HDD set to installed?
        • mandongo
          • Mar 2021
          • 32
          Where can I find the HDD menu?
          The machine was working fine 1 week ago, suddenly the admin and service passwords were changed and the scan-to-folder profiles disappeared. I have resetted the passwords, but still have problems with scan-to-folder.
          If the HDD is the problem if I change it with blank HDD will this resolve the problem? (Should I place some info before I replace it?)
            • 23010
            The first thing that you'll notice if the HDD is UnSet or failed is the message: "Animation data is not available". Fax and scan functions will also be unavailable. =^.^=
            • femaster
              • May 2011
              • 1527
              Passwords general don't change on their own. I guess I'd also have to wonder how you were able to change the service password back if that was changed. It's not an easy task to accomplish unless you or someone else knew what the new password was somehow.
              Did the copier have a PUBLIC facing IP address and the default (or easily guessed) admin password? Stranger things have happened when the copier is accessible from the internet and someone out there in the world wants to be a problem child and mess with settings and passwords.
              • mandongo
                • Mar 2021
                • 32
                I don't get this message. So everything with the HDD should be OK.
                • mandongo
                  • Mar 2021
                  • 32
                  The passwords somehow were changed. The people working at that office don't know how to enter the service menu, neither to change the passwords. I don't know what happened.
                  I resetted the passwords with A145FW.tar via the USB maintenance slot.
                  • mandongo
                    • Mar 2021
                    • 32
                    This is the "Security" tab I see when I log in as administrator. There is no "Restrict User Access" there...
                    • copier tech
                      • 8236
                      If the HDD is UNSET the machine will not display the animation guide missing message.
                      • progoffice
                        • Nov 2008
                        • 337
                        [ATTACH=CONFIG]49748[/ATTACH]
                        You're also missing the "Box" tab and "Store Address" Tab, even when logged in as administrator. My guess is your HDD is not set, not working or missing.
                        • mandongo
                          • Mar 2021
                          • 32
                          Thanks for the answer!
                          If I replace the HDD with new one, it has to be blank (no data on it) or I must copy some data on it?
                          • copier tech
                            • 8236
                            You can fit any 320gb HDD when you turn on the copier it will ask you to format choose yes, reboot & you should be good to go.
                            • Synthohol
                              • 5922
                              Check in service mode system 2 I think, click hdd as make sure it is set to "installed" or replacing it won't do anything if it doesn't look for one due to an improper setting.
                              If it shows unset, hit installed. It may not highlight right away, I've seen it take up to 30 seconds to reflect the change.
