Konica Minolta C284e firmware Installation problem
  • danbb
    • Jul 2021
    • 6
    I have been trying to get a C284e to take new firmware, and run into problems every time. Current is G00-C8. Trying to flash GDB-M1 to solve issues with SMB1. SSD firmware is at 6.03 currently, updated from 6.02. I have tried 4 different flash drives, a 1 gb, 2gb, 4gb, and 8gb, from various manufacturers (verbatim, patriot, and Sandisk). The machine accepts 3 of these flash drives if I have the SSD update on them, but if I instead put the FW update files in the root of the drive as instructed, I get an error "this is invalid external memory". I tried then using the ISW update method, using the provided batch file to create a .tar, and running a FTP server. but I get an error "failed to get information from the Firmware Server" after the firmware file is downloaded. If I try to download and install the firmware through the web interface, the machine will download the update, show the new version as available, but when it tries to install, says "file not available on firmware server". I can verify with FileZilla that the file is indeed requested, downloaded, and that the client closed the connection after the download is complete in both cases. I tried reformatting the hard drive, and get the same issues. Does anyone here have any ideas? Any reason this machine shouldn't take the new firmware?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Re: Konica Minolta C284e firmware Installation problem
    You only copy the contents of the F/W folder to flash drive not the whole folder. That is usually mistake made.
    • danbb
      • Jul 2021
      • 6
      Just to confirm, in my case that would be a folder called A61F0Y0-F000-GDB-M1(00), and in it it should have folders like work_fw, SataF, module, iptables, fw, bin, app, and several files, like the ramdisk, initramfs, etc.
      • Synthohol
        Certified Konica Expert
        • 5846
        yes, that is what goes on the root of the flash drive.
        • danbb
          • Jul 2021
          • 6
          That's what I have on the root of my flash drive. Just get the "error this is invalid external memory"
          • Synthohol
            • 5846
            and its plugged into the service port in the back right?
            ive seen similar when ssd is blanked and an incorrect machine and type are set back to ff for both.
            its something to check
            • Synthohol
              • 5846
              the firmware you are trying to use is C224e C284e_C364e_A5C10Y0-F000-GDB-M1.exe right?
              • danbb
                • Jul 2021
                • 6
                The file I was using was 224e_284e_364e_454e_554e_A61F0Y0-F000-GDB-M1.exe. I downloaded the one you linked and compared hashes, and it was different, tried it and the machine accepts it. Thanks for the help
                • femaster
                  • May 2011
                  • 1512
                  Yup, the one you were trying to use was for the B&W models. Notice the "C" is missing from the front of each model #. Glad to know that Synthohol got you the correct link.
                  • Synthohol
                    • 5846
                    Request to use SMB2.0 on this product series.
                    DipSW to change support SMB versions for the SMB client functions.
                    DipSW No.219 (bit 2)
                    Software SW No.219 0x00: SMB1.0/2.0 are available. (default)
                    Software SW No.219 0x04: Only SMB2.0 is available. <----------that has to be set and ntlm set to v2 as well. its in admin, network, smb, client settings and somewhere around there.
                    im better at the screen than my burnt memory cells
                    • Zesti
                      • Jun 2009
                      • 308
                      Synthol.... Not burnt memory cells...it should be consumed memory cells.... Be in good health..
                      • copier tech
                        • 8169
                        The Latest Firmware is GDP-M1
                        Firmware Readme C224e C284e C364e GDP-M1.pdf
                        • Synthohol
                          • 5846
                          The OP requested the correct firmware that specifically addressed the smb2.0 issue which I posted.
                          I have no idea where you got that version from but it's not what was requested.
                          Plus he was trying mono fw not color.
                          Gdp fw is not the latest either
                          G20-m1 is latest base and gqw-m1 is the latest special fw.
                          Gdp is 5 fw's ago.
                          • copier tech
                            • 8169
                            Gdp is 5 fw's ago.
                            I just wanted to state that the Latest Firmware is GDP-M1
                            • Synthohol
                              • 5846
                              Maybe across the great pond it is but gqw-m1 is the latest here in special fw.
                              Gdp is 5 versions ago from 2020.
