Buizhub 450i won't come to ready after HDD replaced
  • OEM1
    • Mar 2015
    • 33
    I am not a Konica tech. I have been servicing copiers since 1987. I occasionally work on Konica. I have a 450i that wouldn't boot. Shows the progress screen for about a minute then it reboots and starts over. An infinite cycle. I replaced the "storage board." I loaded the firmware from usb. It downloads all firmware then reboots. But it remains stuck on the progress screen at about 25%. It doesn't auto reboot anymore. Is there a different firmware for replacement of boards versus just for upgrading?
  • tsbservice
    Field tech
    • 8020
    Was the storage board new OEM from KM?
    • Woxner
      • Jul 2011
      • 850
      You need to make sure the proper boot rom is on the machine. May also need to run the 8 series reset tool. Just popping in a new storage does not work. Also if you did put in a used board you must do the reset tool. This is never a straight forward process
      • OEM1
        • Mar 2015
        • 33
        OEM New. What do you mean by boot ROM?
        • mascan42
          • Oct 2008
          • 485
          Do you happen to know what the firmware was before it failed? Was the old storage board the same size as the new one? If not, it may need the Boot ROM updated to be compatible.
          • OEM1
            • Mar 2015
            • 33
            The new board was smaller. Can you send the Boot ROM?
            • copier tech
              • 8169
              The boot rom is included in the main firmware. Follow the pdf to update the boot rom.
              • Ziggy
                • Feb 2018
                • 768
                Yes boot rom should be updated before loading or even updating firmware
                • OEM1
                  • Mar 2015
                  • 33
                  Ok. Got it going. Gotta rag on Konica. Every other manufacturer's firmware updates everything. Why in the world is the Boot program in the firmware but doesn't update? So stupid.
                  • Ziggy
                    • Feb 2018
                    • 768
                    Welcome to the world of i-series
