C3080 Image problem in Bk
  • remati
    • 149
    Hello people
    In a C3080 Press have this image problem
    Thick line in the CD direction of the sheet, and about 6 cm from the end of the sheet. It only happens on black. It's not a drum, it's not a developer.
    Please See attached photos
  • lartis.aineias
    • 78
    Remove the metal plate on 2nd transfer roller an you are ready! ? This with 2 skrew an a film on top!
    • remati
      • 149
      Thanks your reply ...but my problem is tha black line about 6 cm from the end of paper
      • Synthohol
        Certified Konica Expert
        • 5892
        id start with the charge roller.
        [edit]oh, CD. sorry.
          • 23010
          If that line is crossfeed, it may be a compression. You can get that defect if the rubber registration seal is warped or damaged. A bad second transfer roller can give you that same defect. Another factor can be how heavy the media is, how much it curls, and if it is set to the correct media type, and de-curl settings.
          If that line is in the feed direction, it's something totally different ... =^..^=
          • remati
            • 149
            Thanks for the teply.
            This problem only happens with the black color. Using test card 53 or others ,only happens with black color. If it have a registration unit, it will be happen in all colors.
            This issue happens with any paper and weight.
            • Ziggy
              • Feb 2018
              • 802
              Pulled attached from troubleshooting guide hope it helps. Send me your email and I can send the entire trouble shooting guide
