Konica Minolta Bizhub C258 Mono / Greyscale Image Quality
  • insigniawales
    • 29
    [CQ] Konica Minolta Bizhub C258 Mono / Greyscale Image Quality
    I have a copy quality issue on a bizhub C258, only on the greyscale / mono prints
    There was a mark on the transfer belt initially so I changed the transfer belt sleeve in oppose to the transfer belt unit - this is the first time I've done this and I'm not sure how succsesful this is or not. Any comments on this method please let me know.
    I also changed the Drum unit and changed the black developer unit - problem still persisted.
    Its only happening on mono / greyscale prints. - so I'm this steers me away from the transfer belt as this would happen on all of the colours.
    Any help or suggestions much appriciated.
    C258 Fault
  • Gaffers01
    • May 2011
    • 335
    Ok, so was it doing this before you changed the belt?
    Was the drum unit new? Genuine?
    Have you cleaned the sight glass under the drums ?
    Have you run the calibrations in the service screen?
    • aberock
      • May 2022
      • 124
      why not clean the laser unit 1st before change the most valuable ITB film hehe
      • insigniawales
        • 29
        It has had a new remanufacured drum (k) x 2
        Cleaned the lsit glass on the laser unit,
        Run all of the calibrations in service mode.
        Before we changed the belt unit we had a mark on the prints, so the image below is before the transfer belt replacement.
        C258 Fault
        • aberock
          • May 2022
          • 124
          C258 Fault
          check fuser unit for the mark
          • Ziggy
            • Feb 2018
            • 731
            Pull laser unit to clean the glass. The wand does not always clean the glass good enough
