Scan to Email slows then stops
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Hi All,
    I have a client with a C458 that is having problems with Scan to Email, where after initial configuration it works fine, but over time, the send time slows until it won't sent at all.
    The current workaround is to switch setting the SMTP Server Address from the domain name to the IP address and back.
    Has anyone had an issue like this?
    My thought is to update the firmware, but the C458 is currently running special firmware GC1-X8. Is there an update to the special firmware, or do we need to get it to GCQ-Y2. If so, what is that procedure?
    Thanks!
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    I would check DNS settings, as when changing from to an ip address and back helps, worth checking (or put it temporarily on dchp and see what DNS it gets)
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • Synthohol
      Certified Konica Expert
      • 5823
      Software Switch No. 25 Setting
      HEX Assignment: 60 Function Version 7
      hey, sometimes a simple oversite like the tx speed, you can lock down 100tx duplex.
      also the silliest one that crippled a school, the friggin time on the machines was an hour off and the smtp server refused the connection.
      hope its that simple if the hold-up is on the machine side.
      also what does the smtp server say? is there something in a log that can assist?
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 149
        Yep, we tried that... But thanks!
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 149
          SW 25 is correct, as are the relevant time settings.
          We'll have to get back to the companies IT staff to review the logs on their mail server to see if it's picking up a problem. But, from what we can see, the traffic isn't leaving the printer, although it shows as sent... which is why I was thinking firmware.
          • tsbservice
            Field tech
            • 8009
            It's not working, then I would go for latest firmware.
            • copier tech
              • 8144
              Originally posted by FuserNoob
              Hi All,
              Thanks!
              Any issues with printing? sounds like a network issue, high traffic.
              Why is the device is on special firmware ? if no reason try updating to the latest.
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 149
                And....we're back to my original question.
                The C458 is currently running special firmware GC1-X8. Is there an update to the special firmware, or do we need to get it to GCQ-Y2. If so, what is that procedure?
                • Synthohol
                  • 5823
                  put the FW000xx folder in its entirety on a 4g or smaller flash drive formatted fat32
                  turn off main power, insert drive in front panel usb, hold down stop button and turn on machine.
                  when you see the black dot and a beep you can let go.
                  FW will start automatically but you can hit start if its blue
                  should reboot when done.
                  • FuserNoob
                    Service Mgr, CISSP
                    • Jul 2022
                    • 149
                    We use 32g flash drives, I'll call 2005 and see if I can find a 4g and try that Thanks
                    • Synthohol
                      • 5823
                      im not being funny, its what is required.
                      very few 8g sticks work.
                      4g is your best bet.
                      • Woxner
                        • Jul 2011
                        • 848
                        you can back up the network and address book then do logical formatt of the hdd. emails and faxes run through this. its helped for me. since its says sent and no traffic i would try it
                        • KMFLT3CH
                          • May 2017
                          • 232
                          Old wives' tale. I use a 64gb Kingston stick for all models ending in 7, 8, 8e, 0i, 1i, never gives me an issue.
                          I would flash straight to GCQ-Y2 - the special firmware you're running now is over 4 years old. No dipswtich to change either, both are function version 4.2
                          • copier tech
                            • 8144
                            I have experimented with various USB drives to update firmware on many manufacturers & surprisingly this little 32GB USB C dual drive worked fine.
                            • Synthohol
                              • 5823
                              i never had any luck with drives bigger than 4g for FW.
                              jersey luck i guess.
