C-3826 fuser code
  • joelcarrara
    • Jan 2017
    • 50
    C-3826 fuser code
    Hello-We recently got a c-3826 code on a KM Bizhub C458. Replaced the fuser with a brand new one, reset the code, and it keeps coming up as soon as we turn on the machine. We tried multiple fusers and reset the code multiple times. No matter what we do as soon as we power up after reset the code comes up (almost immediately after it turns on). Has anyone encoutered this and/or have any thoughts how to solve? thanks
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5888
    Check the fusing unit-MFPB CN12E for proper connection and correct or change as necessary. (bizhub C458)
    may be a bad mfpb too.
    • joelcarrara
      • Jan 2017
      • 50
      Thank you so much for your assistance! We will try tomorrow and report back.
      • joelcarrara
        • Jan 2017
        • 50
        Is it possible to change to a used MFPB board off another c458 machine?
        • Synthohol
          • Mar 2016
          • 5888
          folks have done it before there is a procedure i believe.
          you may be better using hytec repair advanced exchange.
          they are partnered with konica so it should be a good replacement on the cheap. (with 1 year warranty)
          https://www.hytecrepair.com/Default....D=PartsCatalog
          A79MH02102
          dont forget to swap the IC chips
          • joelcarrara
            • Jan 2017
            • 50
            A79MH02102
            thanks so much for your help!
            • Ziggy
              • Feb 2018
              • 801
              If you use a board from another machine run the 789.tar file three times before trying to boot machine. The set machine and type and load firmware
              • joelcarrara
                • Jan 2017
                • 50
                thanks so much! Is this something we can get from the service/firmware downloads from the Konica Minolta website?
                • Ziggy
                  • Feb 2018
                  • 801
                  [QUOTE=joelcarrara;n1575513]thanks so much! Is this something we can get from the service/firmware downloads from the Konica Minolta website? [/QUOT
                  sent reset file
                  • Synthohol
                    • Mar 2016
                    • 5888
                    thats dangerous to just be putting it out in public, you can upload attachments in PMs now.
                    just sayin.
                    • tsbservice
                      Field tech
                      • 8049
                      Originally posted by Markks
                      sent reset file
                      Good edit ๐Ÿ‘
                      • joelcarrara
                        • Jan 2017
                        • 50
                        Many Thanks to Synthonol and Markks for their help and assistance as this is now fixed. Our tech replaced the mfpb board and that did the trick. It took a while but all good--the machine is back running!
