Can you remove finisher from C3851FS and install tray from C3851
  • printajsifajl
    • Jul 2024
    • 40
    Customer's C3851FS is making noises. They don't need the stapling function. Is it possible to remove finisher and install output tray from nonFS 3851?
    I read somewhere that disabling finisher is possible. Would that make device basically same as with c3851 non fs tray?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4764
    I don't think output tray is the same but not 100% sure. The FS paper exits the front and the 3351 paper exits like most Bizhubs from side.
    • Albonline
      • Sep 2008
      • 1153
      you can disable the finisher.in parts isolation. but i think it will still issue a erratic jam code.
      • copier tech
        • 8200
        I believe it is not possible to physically remove these finishers.
        • TRJS
          • Mar 2018
          • 16
          You can remove not sure about tray.
          • KMFLT3CH
            • May 2017
            • 242
            I've isolated the finisher on a few of these, the machine works fine with it isolated. The paper comes out the same as it would on a regular non-FS machine.
            • printajsifajl
              • Jul 2024
              • 40
              Thanks KMFLT3CH.
              • adecanmin
                • Oct 2010
                • 321
                How do you isolate the finisher? I checked the service manual. Don't know where to look.
                • adecanmin
                  • Oct 2010
                  • 321
                  I found something in the manual. It talks about the function. Does the finisher have to give a service code before you have the option of putting it in isolation? Not sure on this one.
                  • mascan42
                    • Oct 2008
                    • 485
                    Service mode -> System 1 -> Problem Unit Isolation -> Set Finisher -> Apply -> Reboot
                    That's the customer-accessible way of disabling it, but it doesn't always work.
                    I never understood why they invented such a complex finisher for a machine that doesn't need one. Half of them broke down within a year.
                    • adecanmin
                      • Oct 2010
                      • 321
                      Thank you sir. Yeah that finisher is a piece of crap.
