FD-503 pamphlet folding jam
  • nullskull
    Learning
    • Aug 2023
    • 485
    Hello, I am back once again lol. I have this FD-503 folding unit that keeps jamming in the same place between the main body and where it enters the the pullout folding unit. It does the same thing for different types of paper and folds. I'm not 100% sure but it seems like the unit doesn't even power on when the paper arrives or else it's just stopping as soon as it enters. My guess is there is some broken sensor
    This gallery has 3 photos.
  • Ziggy
    • Feb 2018
    • 802
    Open door and jig interlock you should see everything check home. also leave door open and run it to see if the rollers are turning. What jam code are you getting and which model machine is it mounted to?
    • nullskull
      Learning
      • Aug 2023
      • 485
      Hello, It's mounted to a 1250p. I opened the door and stuffed some paper into the sensor to see what it was doing when it jammed. It appears that the folding unit is not spinning up when the folder is activated. The post insert will grab the paper and it works fine until it hits the actual folding unit. I'm not getting any code on the screen and the report I printed out shows nothing either somehow. I should mention when i close the door or fool the sensor it'll spin up like usual for a moment but not in operation.
        • 23010
        And the jam code?
        • nullskull
          Learning
          • Aug 2023
          • 485
          And the jam code?
          Was looking for it. Can't find any jams for that under the report i printed out. Last jam code was from almost a week ago on the report
          • nullskull
            Learning
            • Aug 2023
            • 485
            pictures of the jam
            • Ziggy
              • Feb 2018
              • 802
              You can this or a firmware update. If you aren't getting a jam code you may have a bad board in the FD-503​
              • nullskull
                Learning
                • Aug 2023
                • 485
                I ran the recall but it still jams. What board might be the issue?
                • Ziggy
                  • Feb 2018
                  • 802
                  Try updating firmware first , then check the wiring in the fold unit . as far as board I would get the service manual and use the load check mode to run the motors and gates to see if they are working. Then hopefully you will discover which motor or gate solenoid isn't working and if the none of them are working . I would look at wiring diagram to see which board controls them. Sorry but I dont have time to look it up
                  • Ziggy
                    • Feb 2018
                    • 802
                    • Ziggy
                      • Feb 2018
                      • 802
                      • nullskull
                        Learning
                        • Aug 2023
                        • 485
                        Not sure why my post is marked unapproved
                        I think I found the issue. The 70-06 I/0 check causes a loud almost grinding noise. While the 70-07 check seems to work fine. Same motor different rotation direction.
                        • Ziggy
                          • Feb 2018
                          • 802
                          When pulling it apart be careful. Some folding unit the gears are timed . If you get then back together wrong you will have a major problem
