FIERY IC417 ERROR
  • romario
    • Jun 2020
    • 192
    FIERY IC417 ERROR
    Hello group, can someone help me with the system software of the fiery ic 417 version 2.1 for km print 3070L, I have versions 1.0, 1.2, 2.0, I load the fiery everything fine but it does not recognize the paper trays
    thanks
  • Synthohol
    Certified Konica Expert
    • 5814
    can you add the tray manually?
    if 2 way communication is not checked that could be it too?
    make sure the driver is set to TCP\IP LPR port 515 with Print as the port name for best results.
    • romario
      • Jun 2020
      • 192
      If you allow me to add but in the command workstation configuration only tray 1 and 2 appear, and the machine has bypass and high capacity tray, the problem is that the correct system software is 2.1 and I only have the 1.2 and 2.0.
      thanks
      • Synthohol
        • 5814
        crap, sent you a PM but thought i had 2.1
        sorry for the false hope.
        • Ziggy
          • Feb 2018
          • 710
          PM Sent
          • romario
            • Jun 2020
            • 192
            Originally posted by Markks
            PM Sent
            thanks
            thanks
            • romario
              • Jun 2020
              • 192
              thanks
              thanks
