Hello,
I' m Ricoh and Sharp technician but i have at one of customer Bizhub c250i (and c300i but this one still works). The problem was as always fusing (I thought that Sharp had bad fusers in MX-xx61/71 series
. I changed settings (sw, temp and smart fusing) in April and c250i worked about 2 months without any problems. One week ago the customer reported c3826 and "settings doesn't work and printer doesn't print". My colleague was there and saw c3826 (fuser problem) and ce201. I knew about fuser change to v2 so i ordered v2 version. After change old fuser to new by first run i have now c-c180 and sometimes very rarely ce201. Before fuser change i saw notification like "pdf/a font not installed". All diagnostics tests in CE mode are good. All is OK. Bizhub thinks that his condition is perfect
First after fuser change I updated of course firmware to ver. AA2J0Y0-F000-G00-Q6. So errors are after firmware upgrading too. After that I formated SSD (256GB Phison) logical then physical. I initialized machine (clear all data). Now something interesting. In service mode stop-9-Billing-Authentication Device 2- i have only checked form Authentication Device 2 and there is no UNSET form. Machine of course doesn't have card reader. Am I right that this can be base board or cpu board? In detailed trouble codes i have 0x1FFF together with c-c180 (95 times). Is there anything else that could confirm cpu or base board defect? I don't have any parts for these models. I have limited knowledge about Minolta. Usually I work with Ricoh and Sharp and Xerox. Total counter is only about 8000 pages...
