SMB sending Error on C224e
  • AlaskaCopyTech
    • Jan 2024
    • 78
    [Error Code] SMB sending Error on C224e
    Hello All,
    I am pretty stumped on this one. I have a C224e that is throwing a 107 error code no matter what I do. I have tried updating the firmware, changing authentication settings but to no avail. Have I overlooked something simple? Is there a software switch I need to flip?
    Thanks in advance.
  • Tech09
    • Apr 2020
    • 147
    Any changes to their network? The customer may not even know if there has been a change or not without checking with their IT.
    • Synthohol
      Certified Konica Expert
      • 5894
      i always check if i can see the shared folder from another PC.
      and what credentials are used to access.
      • JMS
        • Apr 2023
        • 30
        Can you ping the Scan-Target-PC?
        Scan per IP-Adress or per Hostname?
        Is the SMB-Version correct? SMBv1 ist mostly deactivated. Latest firmware (GDU-M1 Function-Version 7.0) brings SMBv2 to 4e-Series.
        Has the Target-PC a firewall with whitelisting?
        We have customers with all of this.
        • Duplicator
          • May 2022
          • 255
          +1 on this.
          Computers will give you a more meaningful error than the Konica will.
          Or WINS? If you are using a hostname, check the DNS servers.
          Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
          If I helped you out, please give me a thumbs up! It helps my reputation.
          • AlaskaCopyTech
            • Jan 2024
            • 78
            Hello everyone,
            I had IT go through eveything and it seems they had the credentials messed up for the copier on the server side. Looks to be resolved now as I just sent a scan, no problem.
