i option installation
  • jwai
    • May 2018
    • 509
    Hello,
    I wanna ask i option can be set up on copier that hasn't be connected internet?
  • AlaskaCopyTech
    • Jan 2024
    • 78
    Kind of a hard thing to do but I am about 99% sure your Liscense code relies on an internet connection to validate with the server, you can always try entering the liscense code in service mode or admin but I don't think it will be helpful.
    • Synthohol
      Certified Konica Expert
      • 5851
      doesnt the i stand for Internet?
      • tsbservice
        Field tech
        • 8026
        Nope, i is always "incomplete".
        • jwai
          • May 2018
          • 509
          i-option
          • jwai
            • May 2018
            • 509
            Indeed I'm first time order i-option from KM, it's a certificate paper with a code on it?
            • JMS
              • Apr 2023
              • 28
              You should get the license-code per mail.
              And you need internet for activation.
              • Gift
                • Mar 2011
                • 2459
                You can install/uninstall i-options(aka LKxxx) if you have access to KM's LMS - the MFP doesn't have to be online.
                • kingarthur
                  • 1374
                  No, you don't have to be online, if you have access to the LMS,
                  • DeWalt_Man
                    • Jul 2023
                    • 24
                    Originally posted by jwai
                    Hello,
                    possibly, the ioption is generated using a "sale code" given to you by our lord and saiviour, konica, which you put into their validation website, that uses the seriall# and their code to generates the validation key for the machine. i dont the validation key is transferable, and dont want to play around with a key that costs thousands. but the purchase code might.
                    • jwai
                      • May 2018
                      • 509
                      thanks a lot
                      • jwai
                        • May 2018
                        • 509
                        I obtained license code and function code from LMS website.
                        Enter license management setting and input these 2 codes, press apply but machine showed " unable to confirm setting ".
                        The machine only connected on intranet, how to fix this issue?
                        • kingarthur
                          • 1374
                          What i option are you trying to install. You shouldn't need an internet connection doing it the way you have done it, i do them all of the time. When you went on the LMS, did you put in the right serial number for the device that you want to install the i option on
                          • jwai
                            • May 2018
                            • 509
                            I try to install LK110v2.
                            I put right serial number.
                            And WebDAV server setting need to set before input license and function code?
