C227 internal error
  • jwai
    • May 2018
    • 508
    C227 internal error
    Hello,
    One bizhub C227 sometimes displayed internal error and reboot itself, when user copy / scan document through original glass.
    I check the trouble code history, the codes ranking are CFA17>CDFA0>C9401, so I reconnected the flat cable and clean the scanner section.
    ( F/W version G00-Y0 )
    Any suggestion about this issue?
  • Albonline
    • Sep 2008
    • 1147
    Re: C227 internal error
    Originally posted by jwai
    Hello,
    ( F/W version G00-Y0 )Any suggestion about this issue?
    I have seen the flat cable breakdown on units with high scan counts. the repeated flexing wears the conductors out ,you can actually see the cracks is you remove the teflon backing tape.
      • 23006
      I think I'd start with the CCDB. We've seen quite a lot of CCDB failures on 754e series, 658 series, 808 series, especially in very high scan volume environments. =^..^=
      • Albonline
        • Sep 2008
        • 1147
        c227 is not a konica scanner . no ccd uses cis built into first mirror/lamp unit (cis unit)
          • 23006
          Thanks for the correction! =^..^=
          • jwai
            • May 2018
            • 508
            so you consider the flat cable is the most possible cause?
              • 23006
              Something like this?:
              I've seen this on Toshibas. =^..^=
              • Albonline
                • Sep 2008
                • 1147
                you can see the broken traces if you inspect the ribbon cable. if there are ripples in it, its falling apart on the inside.
                  • 8141
                  Hello,
                  I'd start first by updating the firmware & then the function version.
                  When scanning/copying the HDD is being written to so you could have a failing HDD.
                  • zoool
                    • Nov 2016
                    • 52
                    look for this firmware A7AH0Y0-F000-GC2-K7-990-CHECKSUM-b131
                    i have that issue in b/w 227
                    • jwai
                      • May 2018
                      • 508
                      The printing is OK, copyscan through document feeder is ok, mainly occurred on copy/scan through original glass.
                      • jwai
                        • May 2018
                        • 508
                        I updated the machine with GC2-W4 firmware and test a period, this month I visit and check the error call times, 9401 > FA17 > FC06.
                        Now I consider it may cause of IR unit, flat cable, MFPB or other else?
