1250P fuser problem
  • nullskull
    Learning
    • Aug 2023
    • 469
    [Error Code] 1250P fuser problem
    The fuser got a code and I think the mechanism that lifts the lower roller against the upper roller is stuck.
    PXL_20240930_195221862.jpg PXL_20240930_195205368.jpg PXL_20240930_195235089.jpg
    The bearing for the upper roller is not even sitting on the bottom of the case. Is there a way to rotate the shaft on the first photo? It appears locked. I think what happened was a fuser code popped up and the operator just turned off the machine.
  • Synthohol
    Certified Konica Expert
    • 5875
    is the pressure cam up or down?
    • nullskull
      Learning
      • Aug 2023
      • 469
      It is in the up position. Or close to the uppermost position if that makes sense. i'm guessing you mean the main shaft underneath the springs and across the entire piece?
      • wjurls
        • Feb 2017
        • 498
        What code are you getting?
        • nullskull
          Learning
          • Aug 2023
          • 469
          It was a C3906 code. I switched out the fuser unit for a backup one. Turns out it just needed a dipswitch reset. It happens sometimes with the machine. Meanwhile i'm left with the original fuser unit that's locked in the up position. I unscrewed the top so i'd have to really place pressure on the rollers to close it again. The machine is running perfectly now with the other unit so i'm just left with my own error of taking the first unit out when all il needed to do is change the dipswitch. Still new to this haha
          • wjurls
            • Feb 2017
            • 498
            You should be able to close the top still. That's why the screws for it are long. Just make sure you tighten them down evenly across and not all at once per screw.
            • nullskull
              Learning
              • Aug 2023
              • 469
              Ok Thanks i'll do that.
                • 23010
                You can release the pressure on the fuser by turning the cams. I have had to replace those photointerrupters in the fuser that monitor the lift because they become unreliable.
                • nullskull
                  Learning
                  • Aug 2023
                  • 469
                  Is there a trick to turn the cam? I tried and it seemed pretty stuck.
                    • 23010
                    It's been a while, but one of those shafts has a hole bored through it. You can insert your screwdriver and rotate the shaft 90 degrees.
                    • wjurls
                      • Feb 2017
                      • 498
                      I think that only applies to the 951 that doesn't have an automatic tension system. Just close the lid manually and put it back in the machine. It should see what position it's in and automatically release.
                        • 23010
                        Thanks for the correction.
