C-3110, E-304 and E-301...
  • Oystercopy
    • Oct 2009
    • 623
    Customer says machine will go into these codes, but (seemingly) only when he's trying to print... machine, once out of code, seems to copy just fine, but only goes into code when he tries to print... weird.
    But then again, when I first installed this machine, the customer could not print to it at all, and it wasn't until they replaced computers/routers on their network that the machine came to life again and started to print...
    So I'm wondering if this might have something to do with network print jobs/traffic causing some confusion in the machine?
    Thanks in advance,
    OC
    • 23007
    Re: C-3110, E-304 and E-301...
    Thanks in advance,
    OC
    Did you mention what model that you were referring to? =^..^=
    • Synthohol
      Certified Konica Expert
      • 5823
      its in the title?
      • femaster
        • May 2011
        • 1504
        Re: C3110, E-304 and E-301...
        Originally posted by Synthohol
        its in the title?
        It sounds like I wasn't the only one that thought that was a service code. I had to search before I found out that it was the actual model. Just commenting, I have no useful info for the OP unfortunately...
        • tsbservice
          Field tech
          • 8009
          I would try to change machine network speed settings from Auto maybe to 100 Mbps Full-Duplex or if it's already set to some speed put it back to Auto. Do you have a ping reply?
            • 23007
            Error Signal Reception
            E301: Referring incorrect memory
            E304: Finished due to error outside Qt library
            I did a little reading about Qt, but honestly I have no idea where Qt is integrated on the MFP.
            I'd call this an answer, but not really an answer. =^..^=
            • tsbservice
              Field tech
              • 8009
              As always it won't hurt machine being on latest firmware. Another good idea is to put a little switch between machine and network that seems to fix few odd network related issues for me in the past.
              Turn off all unnecessary network protocols like FTP, IPP, IPV6 etc.
              Good luck.
              • femaster
                • May 2011
                • 1504
                Something just came to me. Does there network have POE (Power Over Ethernet)? If so, make sure that they have it turned OFF on the port that the copier is connected to. In rare cases, even this didn't help though. Like tsbservice stated, try with a small switch in line and see if that helps.
                • Oystercopy
                  • Oct 2009
                  • 623
                  Great replies people, thank you. So, a small network switch, with about 4 ports might do it? (I have one of those in my shop that's available)
                  For reference, this is also a machine, that when I first installed it, it would not print for the customer. You could log in to Pagescope, etc, but you sent a print job and it never printed. While waiting for my IT guy to come back from vacation, the customer ended up replacing several computers and then - miraculously - the machine started to print on its own?! So, in my mind, the possibility that this could still be a network issue is very strong.
                  Plus, he can reboot the machine and it comes back up, can copy off the feeder, etc, but when sending a print job is where he gets the E-304 and E-301 codes.. strange
                  OC
                    • 23007
                    You might treat it like you would a non-print data issue:
                    Change the IP address
                    Check for correct print drivers
                    Check for correct print emulation
                    Check for duplicate IP
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      First thing I'd do is connect a laptop directly to the C3110 via crossover and if it prints fine without errors from that, then the issue is clearly their network.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • mojorolla
                        The Wolf
                        • 2608
                        As mentioned, check the network speed, they don't like auto at GB speed. Also, you don't need a crossover cable anymore, those went away a decade ago. Adjust your laptops NIC cards to create an "ad hoc network" to eliminate the machine as the issue.
                        At the machine, print a Configuration report. At the top, it will shows what the machine "thinks" it is. For example, I had a unit that was set as a generic model and the print drivers would not work. Adjusted a soft switch (bit 10, hex 02) to tell the machine it was a Bizhub, re-loaded drivers and all printing worked after that. These newer models use a hodge podge of various settings to determine what the engine is and how it communicates with other software.
                        Also, if Marketplace is on, turn it off if they are not using it. I have seen all kinds of issues with Marketplace left on. Another known issue is service mode>system 2>set storage type. I don't see it for this model but the E301 is what made me think of this.....
                        Could also consider physical and logical formats as well
                        • tsbservice
                          Field tech
                          • 8009
                          Hold on cowboy...it's an old model C3110 doesn't have all bells and whistles
