Rainbow Streak from C258
  • Mitchell-BP
    • Oct 2024
    • 3
    Howdy all, hoping someone can help even though I am rather inexperienced in repairs on these machines. After fixing an issue that was causing the black ink to double print, a rainbow streak started appearing on the right of items printing out after or during heavy color. It was streaking on 2-3 pages, now after replacing the toner it’s streaking on 5-8 pages. Cracking open the side panel, I found one of the components with a streak (shown below) hoping for solutions, thanks!
  • Woxner
    • Jul 2011
    • 851
    You can try and clean the blade of the transfer belt or replace the transfer belt assy.
    • copier tech
      • 8172
      Where are you located ?
      We can supply you a new cleaning blade to resolve this issue if you're interested.
      www.printerfirmware.co.uk
      • tsbservice
        Field tech
        • 8020
        Call a tech to replace your aftermarket "inks" and start troubleshooting from there.
        • KMFLT3CH
          • May 2017
          • 241
          Time for a new transfer belt.
          • kingarthur
            • 1369
            It's definitely the transfer belt, the device puts that image on the transfer bet, so it can carry out self calibration. The transfer belt cleaning blade, isn't wiping it clean
            • Andrey51
              • Feb 2024
              • 6
              Looks like test patterns that for some reason were not erased by a cleaning blade. I recommend removing the transfer belt and looking what is happening with the belt cleaning unit.
              • Albonline
                • Sep 2008
                • 1151
                if you are using nongenuine toners, clean out your hoppers and get a new cleaner blade for the xfer unit. this may work ,provided your developers are not already loaded with toner fused powder. (aftermarket toner melts in the developer units and ruins the actual developer powder.)
