Missing "Separate Scan" Button on Konica's
  • ezzysi
    • Oct 2008
    • 78
    Hi all !
    We're mainly a Develop dealer, but do have a lot of KM's bought in for refurbs.
    Just realised (pointed out by a customer that's gone from a Develop to a KM device) that all our Develops have a "Separate Scan" shortcut on the Scanning screen but all the Konica's I've looked at do not... screen shots below from a C308 and a +308 both with same settings / firmware etc
    I can't for the life of me figure out how to add it back in on a Konica.. and I'm sure it's pretty simple..... anyone have any ideas ?
    This gallery has 2 photos.
  • Synthohol
    Certified Konica Expert
    • 5894
    is it under application?
    • ezzysi
      • Oct 2008
      • 78
      Yes, still available on both machines under application… customer wants the shortcut back on the main scan screen though.
      • Synthohol
        • 5894
        maybe look here for where to enable it?
        • tsbservice
          Field tech
          • 8053
          Originally posted by ezzysi
          Hi all !
          Very good question 😂
          I have customer with both machines and will happily report my findings once I get there.
          Sure any Konica don't have it by default.
          I'm amused 😁
          • femaster
            • May 2011
            • 1519
            I checked one of the C308 machines we have in our office here and it has the Separate Scan button in that location. I went through all the settings I could think of and I can't see an area where you would be able to customize what shows up on that line under the scan button.
            • tsbservice
              Field tech
              • 8053
              It's too late here but I remoted to my work PC and bring remote panel to our bizhub C250i...sure it has it.
              femaster, thanks for correcting me.
              • femaster
                • May 2011
                • 1519
                OK, I managed to dig REALLY DEEP into things and found out how to untangle the pile of sheet that KM has created around those custom buttons on not only the scan screen, but also the Copy Screen, User Box, etc.
                First off, the setting to add, remove, or modify those buttons on the scan/fax screen is located at:
                UTILITY -> USER SETTINGS -> CUSTOM DISPLAY SETTINGS -> FUNCTION DISPLAY (SEND/SAVE).
                But wait... If you try to go there, most likely you will not find the options to customize those buttons, because by default they are restricted and those settings do not show up.
                You first need to go and allow these settings to show up in the settings menu by going to:
                UTILITY -> ADMINISTRATOR SETTINGS -> SYSTEM SETTINGS -> CUSTOM DISPLAY SETTINGS ->FUNCTION DISPLAY PERMISSION SETTING ->SEND/SAVE and set it to ALLOW.
                If you want the ability to customize the copy screen or other areas, you might also want to ALLOW the COPY/PRINT setting.
                Now go back to the first area in USER SETTINGS and you should be able to see the option now to allow for the customization of those button on the scan screen and set Function #7 to the Separate Scan setting that you want to show up.
                • tsbservice
                  Field tech
                  • 8053
                  If you want the ability to customize the scan screen or other areas, you might also want to ALLOW the COPY/PRINT setting.
                  Awesome! I love digging deep into machine's secrets being mechanical or software, service or admin
                  • ezzysi
                    • Oct 2008
                    • 78
                    Morning everyone!!
                    Just got into the office and tried the above...... Works like a charm
                    Thank you everyone that took the time to reply, another little niggle sorted!
                    • kingarthur
                      • 1385
                      The new iSeries come with it activated now, I used to automatically set it up, when I installed it on previous models
