C458 Account Tracking and User Authentication for MacOS Sequoia 15.1
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 150
    I have a client with a C458 that is trying to set up Account Tracking and User Authentication for a handful of users running macOS Sequoia 15.1.
    For the life of me, I can't find in the print dialog where to enter the username and password.
    Can anyone out there offer a clue?
    Thanks!
  • Duplicator
    • May 2022
    • 248
    The settings are found in the print dialog under “Output Settings”. Check the box for User Auth and/or account track. A new dialog box may appear to ask for credentials. Make sure to tick the "save" box. If it appears completely grayed out you may have to enable it in CUPS.
    Please note, this is a per user setting. If a new user account is created, the settings will not transfer.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 150
      Yeah...the problem is that my client can't find the "output setting" option at all in Sequoia, but has no problem with Sonoma and earlier.
      • Ziggy
        • Feb 2018
        • 785
        It may not be working because KM hasn't released a driver yet for Mac 15.1. The newest driver I see is for MacOS Sonoma 14.x .
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 150
          Thanks, that's a possibility.
          The problem, as I understand it however, is an Apple issue. Where in the MacOS print dialog is the user authentication hiding. Like frikkin' Waldo!
          • kingarthur
            • 1374
            Thanks!
            Check your PMs
            • Duplicator
              • May 2022
              • 248
              One "fun" thing about Konica drivers is...they are OS version dependent. If the customer updates macOS and not the driver it can lose the layout info and when it does every setting for the copier will just be listed in a massive row. This also happens if they use the wrong version of the driver. macOS 15 works with the 14 drivers or at least has been for the machines we have ran into.
