Universal printer driver (UPD) vs UPDv4
  • DeWalt_Man
    • Jul 2023
    • 24
    with the new series of machines that have been released, KM has got rid of spesific drivers for the new machines. so with the c250i it had c250i/c300i/c360i spesific drivers, but now its only upd and updv4.
    does anyone know what diffrences there are between the universal pcl drivers for the 301i/ c251i
  • Duplicator
    • May 2022
    • 246
    Yes. Type v4 drivers run in user space while the regular universal type 3 drivers run at the system level. The regular type 3 universal drivers support WAY more models than the type 4 version. I recommend using the type 3 one if you can.
    However, that being said, at this time of writing the newest version of Windows 11 24h2 has a bug that will cause the type 3 version to hang and you MUST use the type 4 version on that version of Windows. This is an issue since it will leave people with old copiers on Windows 11 24h2 without a working driver potentially (i have not had a chance to test this yet). Also anyone who updates a computer from Windows 10 or Windows 11 23h2 to Windows 11 24h2 is going to get a surprise when they try to print.
    In other words, helpdesk support last week....was "fun"....
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • occus
      • 337
      I have now had several customers whose PDF printing froze. I thought the problem was with Adobe Reader. For most of them I solved the problem by reinstalling Adobe and for some I had to switch to Foxit Reader. But thank you very much for the information about the incompatibility and the Windows update.
      • Duplicator
        • May 2022
        • 246
        There is a way to escape. I noticed there was a process (at this point the name escapes me) that runs and uses a decent chunk of CPU time that has something to do with loading the Konica driver. If you kill that process with task manager it unfreezes the application (Adobe reader, Word, whatever) but it doesn't print. At least you can get to a point where you can save the open document.
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5848
          +1 on Foxit.
          do you recall free vista upgrade weekend? when everyone upgraded to vista on friday without checking the driver compatibility first.
          a hundred+ calls on the next monday and for the next month when they couldnt print.
          its sad KM seemed to give up tailoring drivers to the newest OS's.
          sorry you are going through this.
          • DeWalt_Man
            • Jul 2023
            • 24
            it wouldnt happen to be "print filter pipeline host" would it?
            KM did a release on kiku about it on "11-05-2024" (not sure if this is UK or US date formatting)
            • tsbservice
              Field tech
              • 8020
              Yes I think it's related.
              • Duplicator
                • May 2022
                • 246
                Oh yeah for sure. At the time I was working at an MSP. I can't recall how many people we had to tell to "stay on XP". It was all kinds of peripherals that broke because it seemed like no manufacturer had published a driver for their devices yet. Heck the machines we managed directly, we completely skipped Vista and went right to Windows 7 SP1.
                Thanks man.
                I believe that is the one. Really? Apparently I missed that.
                • Woxner
                  • Jul 2011
                  • 851
                  Two things. You can find driver on customer side of km pcl etc even for 1 series. Also there is special firmware for the Adobe not printing and freezing
                  • Cenabby
                    • 3
                    I switched to UPD v4 mainly for better support in newer Windows environments, but noticed certain finishing options were missing, so I keep both drivers around depending on what’s needed.
                    • Cenabby
                      • 3
                      Ran into something similar when setting up a new machine—we had to switch over to the universal PCL drivers too, and honestly, it worked fine for basic stuff, but I did notice slight quirks with advanced settings not showing up like they did on the dedicated driver. Haven’t tried the 301i/C251i combo yet though. On a side note, when we moved to an Epson colour label printer setup for packaging, it was smooth sailing—wish all installs were that clean!
                      • femaster
                        • May 2011
                        • 1514
                        Originally posted by Cenabby
                        Ran into something similar when setting up a new machine—we had to switch over to the universal PCL drivers too, and honestly, it worked fine for basic stuff, but I did notice slight quirks with advanced settings not showing up like they did on the dedicated driver. Haven’t tried the 301i/C251i combo yet though. On a side note, when we moved to an [REMOVED SPAM LINK] Epson colour label printer [REMOVED SPAM LINK] setup for packaging, it was smooth sailing—wish all installs were that clean!
                        Nice little slip of a SPAM link into your post there... Did you actually think that just because you chose black text means that nobody would see it?
