Bizhub c284e SMB2 Firmware
  • bkrusz4911
    • Nov 2024
    • 6
    Trying to get scan to file share working after our network admin blocked ftp. Everything points to this bizhub having ancient firmware.
    Does anyone have the latest firmware for this model? From reading different posts, it looks like the latest does support SMB2.
  • Duplicator
    • May 2022
    • 246
    We are using GDU-M1 with dip switch 25 set to 60 for function version 7 to add SMB2. Don't forget to update the SSD firmware to prevent SSD failure on this model.
    Many times on this forum unless you are a contributor many members will not send you firmware. Another option is to contact copier tech at his website https://www.printerfirmware.co.uk/ for firmware.
    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
    If I helped you out, please give me a thumbs up! It helps my reputation.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5842
      i have GDB-M1 for that, (its slightly older than GDU) and set bit SW 219 to hex 0x00and set NTLM to v1/v2. or even 2.0 only if avail.
      and sw 25 to 60 as Duplicator pointed out.
        • 8167
        Thanks Duplicator , yes we would be happy to supply you the latest firmware to support SMB v2.0
        • bkrusz4911
          • Nov 2024
          • 6
          Does the latest firmware also include the SSD firmware as well or is that something separate i need to get?
          • Duplicator
            • May 2022
            • 246
            From what I can recall, there was a special SSD firmware updater. I've attached the readme.
            That being said I believe using regular firmware updates it would show the SSD version along the top of the screen somewhere.
              • 8167
              Yes the SSD will get updated with this firmware.
              • femaster
                • May 2011
                • 1510
                The latest firmware does include updates to the SSD firmware, but it will only update the SSD if the SSD firmware is at least 6.03m. The special SSD update firmware only needs to be run first, to bring it up to 6.03m, if it is currently at 6.02m or lower. See attached Tech Bulletin for details.
                • bkrusz4911
                  • Nov 2024
                  • 6
                  is there a way to see what the ssd firmware is without the tool? It looks like my unit was manufactured in 2015 and i was confused with the tech bulletin since it mentioned anything after Feb 2014 had the fix done already.
                  • Synthohol
                    • Mar 2016
                    • 5842
                    in service mode under firmware version prolly last page to scroll.
                    12.4.2 Procedure
                    1. Call the Service Mode to the screen.
                    2. Touch [Firmware Version].
                    3. Select the appropriate key from 1 to 5 to check the firmware version.
                    • bkrusz4911
                      • Nov 2024
                      • 6
                      Thanks! I just looked and my unit does have the 6.05m ssd firmware. Im guessing at some point they did the ssd fix but didnt update the rest of the firmware.
                      • Synthohol
                        • Mar 2016
                        • 5842
                        do you have the minimum GDB-M1? GDU sounds newer but i dont know if the bit sw is needed with that ver.
                        • bkrusz4911
                          • Nov 2024
                          • 6
                          I dont think so... I dont find those letter combinations on the version page.
                          Here is whats showing from the admin web panel:
                          MFP Card Version A5C10Y0-F000-G00-K2(00)
                          MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
                          MFP Controller Linux Base Linux-2.6.26.8-rt16
                          MFP Controller Kernel Program A5C10Y0-1C00-G00-71
                          MFP Controller SubSet A5C10Y0-1F00-G00-M0(00)
                          MFP Controller A5C10Y0-0100-G00-K2(00)
                          Operation Panel Message Data A5C10Y0-8100-G00-J4
                          Fax Board Controller1
                          Fax Board Controller2
                          Fax Board Controller3
                          Fax Board Controller4
                          Engine Parameter A5C10Y0-0054-G00-01
                          Engine BOOT A5C10Y0-0055-G00-00
                          Scanner A5C10Y0-0023-G00-30
                          Printer A5C10Y0-0050-G00-29
                          ADF A3CE0Y0-0024-G00-10
                          Finisher A3EP0Y0-0071-G00-19
                          RU
                          ZU
                          Panel CPU A55V0Y0-8900-G60-00
                          DSC1
                          DSC2
                          Loadable Device Driver1
                          Loadable Device Driver2
                          SD
                          Voice Data A5C10Y0-C100-G00-55
                          Movie Data A5C10Y0-C000-G00-30
                          Dictionary Data A5C10Y0-B100-G00-00
                          OCR Library
                          Panel Sound Data A5C10Y0-C200-G00-00
                          MFP Controller Thread Image Parameter A5C10Y0-8B10-G00-01
                          MFP Controller PIC Image Parameter A5C10Y0-8A10-G00-01
                          MFP Controller System A5C10Y0-1000-G00-K2(00)
                          MFP Controller Print Controller A5C10Y0-3000-GH0-44
                          MFP Controller Print Controller Font A5C10Y0-3F00-G01-40
                          MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
                          MFP Controller MIO A5C10Y0-5000-G00-J4(00)
                          MFP Controller PIC A5C10Y0-8200-G00-B1
