Machine reset after backup battery failure
  • AVNER
    • Aug 2010
    • 11
    [Electrical] Machine reset after backup battery failure
    Hello forum members
    I have a 364 machine whose backup battery ran out and caused the machine to be reset.
    I reset the NVRAM and entered the serial numbers of the machine and the feeder, and the machine boots like this, what did I do wrong? Maybe the order of operations is wrong.
    Thank you very much
  • tsbservice
    Field tech
    • 8020
    Check and see in service mode that scanner is not isolated for some reason. Nothing dramatic if you don't have some serious issues with CCD or dual scan DF board. Also check scanner serial although I never heard anything about it preventing copy/scan.
    Btw you did it right 👍 😉
    • AlaskaCopyTech
      • Jan 2024
      • 78
      From what I have heard a reset like this is normal when the battery dies. Just make sure to designate thr machine type put in the serial and make sure it's not a generic. Your counter may have been reset but as long as you put the settings back you should be fine.
      • femaster
        • May 2011
        • 1510
        You'll also want to re-enable the HDD in service mode. I'm nearly certain that it comes back up with it disabled (UNSET). Change to SET.
        • AVNER
          • Aug 2010
          • 11
          Of course I played the disk, it didn't work, do I need to insert a serial number for the scanner?
          • Duplicator
            • May 2022
            • 246
            No just for the printer.
            If it won't enable the HDD it may be bad or just not installed.
            Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
            If I helped you out, please give me a thumbs up! It helps my reputation.
            • AVNER
              • Aug 2010
              • 11
              thanks
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                Did you input machine type like other poster mentioned?
