Bizhub 551i
  • copytechman
    • Nov 2008
    • 934
    Bizhub 551i
    Brand new latest firmware, sees Ledger on the glass when you close the document feeder, replaced the one aps sensor and the behavior remains, if i block that sensor it detects letter size properly in both directions on the glass and when theres nothing on the glass. The sensor behavior is the same as a C650i I visited for another issue recently. (very similar model same sensor). Have yet to check for special firmware for the model and thought to reach out here first. Thoughts? (Yes i did the non image erase check with the doc feeder completely open and the lights out with an OK result)
    Let me know thanks so much.
    A.
  • femaster
    • May 2011
    • 1492
    ADF height adjusted too low and the sensor is seeing the white plate as a piece of paper?
    • copytechman
      • Nov 2008
      • 934
      The adf appears the be correct height and the plate under it always touches the glass on any of the konica's I've seen.
      Thank you for that though!
      • femaster
        • May 2011
        • 1492
        I only suggested as I've seen that on a few older models, and once on a XX0i model where lifting the ADF a bit alleviated the size detection issue.
        • copytechman
          • Nov 2008
          • 934
          Hmmm ok, won't hurt to try it I suppose! Thank you. I'll let you know of a result next time that I'm in the area.!
          A
          • Ziggy
            • Feb 2018
            • 710
            I've had a couple of different machines doing this on one I adjusted the front right corner to the lowest possible position . On another I ended up doing a non-image area erase to fix this problem . Another thing is to make sure both sides of the glass are clean, I have had them look clean but the sensors would say original on glass. I clean both sides of the glass with alcohol
