Bizhub 287
  • anor Anoar
    • Nov 2024
    • 24
    Bizhub 287
    Erorr code C-5354
    Malfunction refers to fan
    When I unscrewed the machine, I did not find the fan referred to in the error
  • anor Anoar
    • Nov 2024
    • 24
    The error refers to this fan, knowing that when I opened the printer, I did not find the fan and the printer, knowing that the latest version of Bezhhope 287
    • Synthohol
      Certified Konica Expert
      • 5826
      if you dont see this fan its likely the root of the code.
      • anor Anoar
        • Nov 2024
        • 24
        The fan is not present as in the picture
        Where can I get this catalog for the printer I have?
        • Synthohol
          • 5826
          if you become a contributor or VIP on this site ill send you all the manuals.
          • Synthohol
            • 5826
            fan (except refresh models)
            4139M10001
            dont ask me what the hell a refresh model is though, that you will have to solve yourself.
            • anor Anoar
              • Nov 2024
              • 24
              Thank you
              My printer is on the new model Question: Has the fan been canceled or moved elsewhere?
              • femaster
                • May 2011
                • 1504
                The "refresh model" had a ton of revisions made to it mid-production.
                Originally posted by anor Anoar
                Thank you
                If your machine falls into the "refresh" category, it would appear that it should not have that fan. The duct work and fan were eliminated in the refresh model. I don't really know how the machine would determine if it was a refresh or not, as the main boards have the same part numbers in both versions of the machine. Perhaps it's a firmware thing. The refresh model came out in 2017, so perhaps a firmware update might help to clear that up? Hard to say.
                I've included a copy of the only bulletin I can find on the revisions between the original and refresh model. It seems to mainly deal with parts differences however.
                • anor Anoar
                  • Nov 2024
                  • 24
                  أين المروحة المقصود بالخطأ C-5354
                  • mascan42
                    • Oct 2008
                    • 484
                    If it's a refresh model, but it's looking for the fan that was removed, it might have the wrong firmware loaded.
                    The fan would be mounted over that oval-shaped hole to the left of the board.
                    • anor Anoar
                      • Nov 2024
                      • 24
                      كيف أعرف ما هو برنامج هذا الطراز 287؟
                      مع العلم أنني جربت
                      a7ah0y0-f000-g00-y3
                      a7ah0y0-f000-gcp-y3
                      a7ah0y0-f000-gcm-y3
                      • mascan42
                        • Oct 2008
                        • 484
                        مع العلم أنني جربت
                        a7ah0y0-f000-g00-y3
                        a7ah0y0-f000-gcp-y3
                        a7ah0y0-f000-gcm-y3
                        Under the utility menu, select Device Information. The firmware should be shown there.
                        • anor Anoar
                          • Nov 2024
                          • 24
                          Device Information displays the software you downloaded to it
                          • Synthohol
                            • 5826
                            software=firmware
                            what version is shown?
                            • anor Anoar
                              • Nov 2024
                              • 24
                              A7AH0Y0-F000-GCP-Y3
