fuzzy lines in images
  • rrrohan
    • Sep 2011
    • 1977
    Im getting fizzy lines through prints.
    Its not the MFP sadly. Would you say A7PUM40800 High voltage unit is the next best option?
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: fuzzy lines in images
    do the internal test prints do the same? (halftone and gradation test patterns.)
    • rrrohan
      • Sep 2011
      • 1977
      That is the internal test bird. And halftones do same yes
      Sent from my Pixel 4 XL using Tapatalk
      • tsbservice
        Field tech
        • 8020
        Before start throwing boards I would remove any option and try.
        • Albonline
          • Sep 2008
          • 1151
          judging by the limited info, i would say print head. seeing half tone patterns would be a great help.
          • Synthohol
            • 5846
            Fwiw I've seen a faulty dual scan board do the same.
            I'd remove the board temporarily, change it to no adf in service mode and see if the issue remains.
            I know it sounds weird but if I haven't seen it myself I'd be skeptical.
            5 minute diagnostics
            • tsbservice
              Field tech
              • 8020
              Good call I agree after re-examine test page. I would reseat connectors for PH unit but may need new one.
                • 23009
                By all appearances the fault affects all colors, but to be sure, print this:
                • tsbservice
                  Field tech
                  • 8020
                  [ATTACH=CONFIG]50439[/ATTACH]
                  rrrohan did you find the culprit?
                  • sendpiks
                    • Dec 2017
                    • 21
                    I have similar problem on my BH 452 and solved it when replaced motors, I replaced motor for black drum AND motor for belt, I don't know what motor was the issue but after replacing problem was gone..
