Konica C364e scanner green stripes
  • ferro10
    • Jun 2015
    • 117
    Hi everyone
    A client of mine reports that in the morning the first scans come out with green lines then after about 10 scan works the problem disappears.
    I thought of a CCD problem or of a connection cable do you have other possible solutions?
    defect in the attachment Green squares are only for privacy
    PS: the printer is in the office so not in an too cold environment.
  • Synthohol
    Certified Konica Expert
    • 5824
    are scans off the glass different?
    • ferro10
      • Jun 2015
      • 117
      they are different as documents
      Or do you mean something else?
      • Synthohol
        • 5824
        are you scanning through the feeder or off the platen glass?
        • ferro10
          • Jun 2015
          • 117
          That test is done with feeder. The customer confirms me that the glass scan also comes with the same defect.
          • Synthohol
            • 5824
            ok so likely ccd related then or mirrors could be slightly out of place.
            you could reseat all the cables, ribbons on both ends but dont touch red screws.
            just for giggles, run background data reset and stabilize, then stabilize in gradations and perform all the adjustments (3 each) and see if the result changes.
            that test wont require a screwdriver
            • Woxner
              • Jul 2011
              • 848
              if it clears up just replace ccd. have had many do this. keep it simple. it cant be mirrors so dont piss with them
              • myster
                • Oct 2011
                • 79
                Good morning.
                We had a similar problem on a c652. In the morning the "first hour" failed, the rest of the day it worked fine.
                If it was turned off at night the next morning it would happen again
                We solved it by changing the ccd unit
                  • 23008
                  On machines with high scan volume and very large packets, it's common for CCD failures and intermittent codes C9401, across multiple machine series'.
                  • ferro10
                    • Jun 2015
                    • 117
                    Update
                    I confirm that the problem has been resolved by replacing the CCD
