c754e cyan imaging unit problems
  • myster
    • Oct 2011
    • 79
    Good morning.
    Any kind of help will be welcome...
    The cyan imaging unit for some reason spills all the developer out and into the waste toner container. 3 days ago we changed the development unit for a new one with its initialization chip. The machine was working perfectly. Today the client contacted us with the same problem. We have reinstalled another new developing unit and changed the toner (original). The machine has worked perfectly again, but we think that the machine may have some type of more serious failure and that within 3 days it will fail again.
    Any help is appreciated
    c754e.pdfThank you
    Buenos dias. cualquier tipo de ayuda sera bienvenida.
    La unidad de imagen cian por algun motivo derrama todo el revelador por fuera y al deposito de toner residual.
    Hace 3 dias cambiamos la unidad de revelado por una nueva con su chip de inicializacion. La maquina quedo funcionando perfectamente. Hoy nos ha avisado el cliente con el mismo problema. Hemos vuelto a instalar otra unidad de revelado nueva y hemos cambiado el toner (original), La maquina ha vuelto a funcionar perfectamente, pero pensamos que la maquina puede tener algun tipo de fallo mas grave y que dentro de 3 dias vuelva a fallar.
    Se agradece cualquier ayuda
    Gracias
  • Slammers
    • Feb 2019
    • 109
    Try this thread, there is a PDF in there detailing Cyan/Magenta dev problems on this series of machine.
    It could be the toner vac system at the rear of the DV units that is blocked or the Toner Filter is chocked full. This will cause the Dev unit to "spit" toner onto the drum / charge grid causing the image defect you have provided.
    If I ever replace a Dev on this series of machine I always replace the Drum at the same time, these machines are notorious for C Dev issues.
    i replaced the Cyan DV, and DV Unit and the chip, just a few months ago, the DV is now been used up like it want getting toner, but there's no leak, spill, cyan toner anywhere to suggest a leak,there is over a half a bottle of cyan toner in the machine its OEM, i checked the sliding door at the DV shoot and the machine, its
    • copier tech
      • 8107
      Originally posted by myster
      Good morning.
      c754e.pdfThank you
      Gracias
      The cyan drum & developer should unit come as on unt, they are not designed to be replaced separately, if you are using a non OEM dev unit this could be your issue.
        • 22954
        If the HVT is bad you can get these symptoms.
