Bizhub 456e - printing problem after yellow drum replacement
  • moraoia
    • Dec 2024
    • 5
    Hi,
    Noob here asking for advice about this result:
    Free image hosting and sharing service, upload pictures, photo host. Offers integration solutions for uploading images to forums.
  • Synthohol
    Certified Konica Expert
    • 5891
    can you swap it with the magenta drum and see if it follows the drum or remains in the yellow slot?
    • tsbservice
      Field tech
      • 8051
      Drum was rebuilt?
      • moraoia
        • Dec 2024
        • 5
        Drum was rebuilt?
        Sold as original, factory packaged and sealed ... but you never know.
        Putting back the old one, I get the same result.
        • moraoia
          • Dec 2024
          • 5
          The yellow test result is exactly the same after exchanging drums position.
            • 23010
            It looks charge related, like the yellow developing roller is arcing to the yellow drum. Do you see anything amiss with the yellow developing unit?: broken developer spacer? poor developer coverage at one end? burn/arc marks on the developing roller? broken alignment pin that mates with the front or rear frame? something that's not supposed to be in the developing unit (presumably conductive)? =^..^=
            • tsbservice
              Field tech
              • 8051
              Besides other questions what is correct model perhaps bizhub C454e?
              Remove drum and shine a light towards 9 o'clock in gap where drum seats. You should see developer unit magnetic roller covered with toner/carrier. Yellow in particular is a bit tricky to see but if you see bare metal of magnetic roller it's a sign of developer depletion and you are in deep trouble.
              • moraoia
                • Dec 2024
                • 5
                Model 45c-6e. Waiting for technician
                • Albonline
                  • Sep 2008
                  • 1153
                  that model indication is not for a properly set km unit . it looks to have the factory dipswitch settings played with, or the battery went dead.
                  • moraoia
                    • Dec 2024
                    • 5
                    hmmh. If it's the dip switch, is there any reasons for that? What are the implications of the actual status?
                    • Synthohol
                      • 5891
                      software switch 10 hex 02 is konica instead of generic.
                      • Albonline
                        • Sep 2008
                        • 1153
                        implications are incorrect settings across the board, causing numerous problems . if you can get a certified km tech to work on this i would. these 4 series units are known to have the backup battery go dead.
