C S Remote question
  • Bizhubfixer
    • Aug 2024
    • 14
    C S Remote question
    Hi
    How in C S remote settings on the c308 do I set it up to email the dat files within it to an email address?
    Can some one please help
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5875
    ive never known it to work like that, if you are remoted in just save the XML locally.
    • Ziggy
      • Feb 2018
      • 790
      Originally posted by Bizhubfixer
      Hi
      In order for CR remote care to report to an email address you have to be a dealer and get with Konica to have the machines report to your email address via their CS Remote care server
      • plus-COPY
        • Aug 2023
        • 32
        Hi
        CS remote care is an open system, there are no requirements for additional licenses to use the data sent by the device. I have never heard of the need to authorize KM and use their servers. It is possible to send data about the status or status of the device to any e-mail address. Write what exactly you want to achieve by getting a DAT file.
        • Ziggy
          • Feb 2018
          • 790
          I was referring to the Vcare option of CS remote care. My understanding is for this to work you have get with KM to set it up. I could be wrong. instructions attached
          • plus-COPY
            • Aug 2023
            • 32
            Thanks Markks, this is a very good instruction. It is important to properly set the Center ID and e-mail to send data, 3 date files arrive. 🙂
            • Bizhubfixer
              • Aug 2024
              • 14
              Thanks Markks, do you have the sheet to show the emailed dat file where the data is for toners etc and the format it is in?? we use this system and a crib sheet would be ideal for the emailed dat files
              • Bizhubfixer
                • Aug 2024
                • 14
                do you have a crib sheet to show where the info is on the dat sheet as it contains alot of data
                • Ziggy
                  • Feb 2018
                  • 790
                  I don't have any crib sheet. The only thing I have ever done is set it up to send. I've never seen the data that it sends
                  • plus-COPY
                    • Aug 2023
                    • 32
                    Hi BizhubFixer
                    I sent you an example of a DAT file sent from CSRC/Email to your private email, all important data was marked in the schedule. But to read them correctly you need an application
                    • AdamsRoan
                      • Jan 2025
                      • 1
