C750i setup Scan to Email offfice365 transmits scans without error but not received
  • Tommy D
    • Jun 2020
    • 9
    C750i setup Scan to Email offfice365 transmits scans without error but not received. C250i and C360i on same network scan to smtp.office365 email without any problems
  • tsbservice
    Field tech
    • 8006
    Re: C750i setup Scan to Email offfice365 transmits scans without error but not receiv
    Are the firmware and function versions latest?
    • Tommy D
      • Jun 2020
      • 9
      Thanks.
      Yes. Updated to FW0027
      • copyrooks
        • Oct 2013
        • 208
        Check your DNS on the copier. For a customer at a bank we had the same issue, once DNS was updated their emails starting arriving.
        • Tommy D
          • Jun 2020
          • 9
          Okay. We're going back tomorrow afternoon. We'll let you know. Thanks.
          • Synthohol
            Certified Konica Expert
            • 5816
            fwiw when i run into stuff like that i do an external memory backup of the network and system settings of a working machine and import it into the troubled one.
            sometimes its all the kickstart it needs. and i change the IP back of course.
            • kingarthur
              • 1343
              The only time I've had this problem, is when the "From" address is different to the one you are using to log into in the SMTP authentication section for emails, on your copier.
              • ThisPete
                Too old to care
                • Jun 2014
                • 193
                I've sometimes had similar issues if there is no text in the 'body' of the email, do the subject and body of the sending email have something in them?
                • Woxner
                  • Jul 2011
                  • 845
                  so what version of firmware are you at. FW0027 is not a version but the folder name.
                  these are the versions: latest to oldest G00- K8 function 2.2 GooJ9 function 2.1 G00 G4 function 2.0 G00 E9 Then E35 ANd E 34 which are 1.0
