Bizhub 250i error c-c164
  • cyta123
    • Aug 2015
    • 46
    I have a bizhub c250i with error c-c164. After display error it reboots. I can get into Tech Mode. I updated to the latest firmaware -still the same error, I changed type model according SM - no change. I can't find anything about this error on infohub (Europe).
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Bizhub 250i error c-c164
    From the service manual.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • Synthohol
      Certified Konica Expert
      • 5847
      Why did you change it? What is the first 4 of the serial#‽
      Aa2j is 10 and 1
      Aa2k is 10 and 2
      Aa2m is 10 and D
      • cyta123
        • Aug 2015
        • 46
        Aa2j is 10 and 1
        Aa2k is 10 and 2
        Aa2m is 10 and D
        The first 4 digit are: AA2M so I writed 10 and D but no effect.
        According to SM I made first 3 points of procedure.
        • Albonline
          • Sep 2008
          • 1151
          Aa2j is 10 and 1
          Aa2k is 10 and 2
          Aa2m is 10 and D
          what hardware was just replaced? (this code happens when you try and use used parts from a different copier without resetting them first.)
          • cyta123
            • Aug 2015
            • 46
            Nothing was replaced. The machine just restart itself and error c-c164 appeared.
            • Albonline
              • Sep 2008
              • 1151
              You may need to run the board reset file, set machine type correctly, and then do firmware.
              I strongly suspect some sort of hardware damage here though.
              • cyta123
                • Aug 2015
                • 46
                I will reset machine soon.
                I let you know after that.
                • Woxner
                  • Jul 2011
                  • 850
                  Had one of my techs have this on 250i it turned out the SSHD was flaky. he tried reset and format but had to replace it.
                  • cyta123
                    • Aug 2015
                    • 46
                    Is it possible to buy and install other SSd Memory then AA2JM72M00 (parts manual)?
                    • tsbservice
                      Field tech
                      • 8020
                      Really good question but the answer as far as I know atm is No.
                      Did you tried reset and format?
                      • avecosat
                        • Jun 2012
                        • 305
                        I tried but I didn't get it
                        • cyta123
                          • Aug 2015
                          • 46
                          J formated ssd memory and updated firmware - no effect.
                          First apeared c-164 and then go into self-diagnostic, later machine are frozen.
                          • Woxner
                            • Jul 2011
                            • 850
                            Dont go above G4 or J9
                            • cyta123
                              • Aug 2015
                              • 46
                              Do you think it is a good idea to use a reset tools a789be?
