Bizhub 250i error c-c164
  • Woxner
    • Jul 2011
    • 853
    #16
    Re: Bizhub 250i error c-c164
    you can try but it may have been corrupted. just like the 8 series give it time to work once you turn it back on. see if it will give recover data
    • cyta123
      • Aug 2015
      • 46
      #17
      No "recover data" apeared.
      • bzq
        • Jan 2016
        • 4
        #18
        Originally posted by Synthohol
        Why did you change it? What is the first 4 of the serial#‽
        Aa2j is 10 and 1
        Aa2k is 10 and 2
        Aa2m is 10 and D
        Hi, i have C250Iwith boot hang on 25%. Tried the test firmware, normal firmware (different versions that i had) and no reaction (the USB was good, worked on other machines).
        I did a reball on CPU board and it started reacting on the firmware, did the etst (all OK, CPU, SSD OK), so i did the firmware. It started booting up but gives C-C164 error (machine code was set to 10 D according to S/N and info You supplied) still a no go.
        Can You supply a reset tool and proper firmware? Would be grateful.
        • Synthohol
          Certified Konica Expert
          • 5892
          #19
          try running the GXX repair/diag firmware.
          • bzq
            • Jan 2016
            • 4
            #20
            Did that, tested everything OK, did the recover, told me to do the FW, after FW still C-C164
            • REGSIS
              • May 2016
              • 435
              #21
              Diagnostic tool should piont you to the faulty part (CPU board or SSD board). Replace it and update FW (select correct machine model).
              In my case it was a CPU board.
              • bzq
                • Jan 2016
                • 4
                #22
                diagnostic tool marks everything as OK
                • Albonline
                  • Sep 2008
                  • 1153
                  #23
                  the code say's the cpu has the wrong firmware. there is not a way to clear the cpu board as far as i know. you will probably have to replace it.
                  • Synthohol
                    • 5892
                    #24
                    can you boot into trouble reset, access service mode and see if full diagnostics will work?
                    verify the machine and type are correct booting from a firmware stick if you havent already.
                    • shannu44
                      • Sep 2023
                      • 1
                      #25
                      I am experiencing an error with my bizhub c250i. The error code is c-c164, and after the error is displayed, the machine reboots. I have accessed Tech Mode, updated the firmware to the latest version, but the error persists.tristan tate I also tried changing the type model according to the service manual, but it did not make any difference. Unfortunately, I couldn't find any information about this error on infohub (Europe).
                      • Synthohol
                        • 5892
                        #26
                        Originally posted by shannu44
                        I am experiencing an error (silly link).
                        well that was a non motivating link dumped in the post. was that intentional?
                        we all make typing errors, i just hope you arent spamming this thread for that silly link because that would be lame.
                        • tsbservice
                          Field tech
                          • 8052
                          #27
                          The bots are getting smarter I think they're using chat gpt and integrated their links in real questions. How do you imagine new registered user to make this mistake incidentally
                          • Synthohol
                            • 5892
                            #28
                            using using the "posts awaiting moderation" feature would be impossible in a forum this popular.
                            im trying to remember if there is a feature in vBulletin that wont let you post in any forum until they do a welcome new user post in a designated forum.
                            i was being polite today.
                            • tsbservice
                              Field tech
                              • 8052
                              #29
                              Yes and being polite is good for most of the time. I'm happy camper too... well 😊 most of the time.
                              Being a tech is great job, nobody can turn my screwdriver, period. It makes me feel good.
                              • bzq
                                • Jan 2016
                                • 4
                                #30
                                Yes at this point i can, it marks everything as OK.
