Konica Minolta c6100 Jam??
  • dkaliahsan
    • Sep 2021
    • 13
    [Jamming] Konica Minolta c6100 Jam??
    Hey Guys,
    My Minolta C6100 is getting paper Jams at the M3 section, its not getting past that section, is there a solution for this, I got an error code of C-0130 when doing the paperless run test.
    • 22995
    Re: Konica Minolta c6100 Jam??
    What jam code? =^..^=
    • dkaliahsan
      • Sep 2021
      • 13
      The Code I got is C-0130
        • 22995
        The C-0130 is a PF-707m roller pressure release abnormality.
        With larger media, rather than maintaining a buckle between the rollers of the paper pickup unit, this paper feeder releases the pinch roller pressure to allow the media to pull through.
        I had this erro on a bizhub C1060:
        "C0130" error message, with PF-707, won't clear.
        Roller pressure release motor M10 cannot reach home position. Clean roller pressure release sensor PS41 (was heavily caked with translucent grease). When cleaned, machine comes to ready. It feeds a few sheets before coding out with loud gear noise. The 2nd tooth from the flat on sector gear 36T is worn/flattened.
        Clean roller pressure release sensor PS41 in a cup of alcohol. Replace release cam (A55C 7137 00), and release sector gear 36T (A55C 7195 00).
        • dkaliahsan
          • Sep 2021
          • 13
          Is There some diagram or pictures of what I should look for?
            • 22995
            Respectfully, you might take a look at the service manual. =^..^=
              I bow before thee.
              • dkaliahsan
                • Sep 2021
                • 13
                One more quick question if the machine isn't leveled correct? can i get a paperjam?, or that has nothing to do with it?
                  • 22995
                  It's unrelated to leveling. It's a simple mechanical issue that you won't see until you do some disassembly.
                  And the C-0130 is and error code, not a jam code. There is a difference. =^..^=
                  • Toxic
                    • 696
                    Judging by level of your questions i think it will be the best for you to call some technician who knows what he is doing.
                    • dkaliahsan
                      • Sep 2021
                      • 13
                      So I solved this situation, now I am getting a new error Code C-5109?
                      • Synthohol
                        Certified Konica Expert
                        • Mar 2016
                        • 5789
                        CN118 of PFUDB, CN432 (relay connector), CN433 (relay connector), CN437 (relay connector), CN410
                        of PS40, and the wiring between PFUDB and PS40. Then, repair it when there is any abnormality.
                        5. Replace PS40.
                        6. Replace PFUDB.
                        Table 1: Result check
                        Result check Normal Abnormal
                        START About 4500 65535
                        Deviate from "normal" significantly
                        STOP About 4500 65535
                        Faulty part isolation DIPSW
                        Control while detached
                        • dkaliahsan
                          • Sep 2021
                          • 13
                          5. Replace PS40.
                          6. Replace PFUDB.
                          I got 65535 does that mean the sensor is bad??
                          • Synthohol
                            • Mar 2016
                            • 5789
                            significantly
                              • 22995
                              Does it even have a centering sensor? I doubt it.
                              I seem to recall that the centering sensor assembly must be installed when the PF707m is used on a C6100.
