Plastic Cards
  • Hishamawada
    • 174
    Plastic Cards
    Hello my friends, for KM techs .
    I want a printer that can print me on plastic cards (PVC) along with other type of paper (with different gsm).
    Please I want to know what is it name ? What is the best model ? A general overview about it and its maintenance.
    If i can get an approximate price of it would be great .
    Thanks in advanced.
    Sent from my M2101K6I using Tapatalk
    • 8146
    Re: Plastic Cards
    Thanks in advanced.
    Google search under ID Card printers.
    The Zebra is ZC10L is approx $8,000 USD.
    • Hishamawada
      • 174
      Re: Plastic Cards
      No i am looking for konica minolta printer that can print on plastic cards , not just a small printer. Along with other paper types options
      • Hishamawada
        • 174
        Re: Plastic Cards
        I have searched and find AccurioJet KM-1e. But I want to know if there is any other Konica minolta printer that can do the same job .
          • 22999
          Re: Plastic Cards
          I haven't had anyone try to print ID cards on a Konica Minolta, but I do have some experience with a customer doing these Identicard branded pre-perforated cards on a Kyocera FalconIII.
          Identicard pre-perforated ID cards consistently jammed J10 because of breaking on the pre-perforations and the cards that did pass were warped from the fuser heat. The product label indicated use on INKJET PRINTERS, of which FalconIII is not.
          My suggestion is to purchase the Zebra based device if you have more than one or two cards to do. =^..^=
          • Synthohol
            Certified Konica Expert
            • 5806
            Re: Plastic Cards
            i cant imagine a laser printer that will print on plastic well, the fuser alone comes to mind as heat and plastic dont mix.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4632
              Re: Plastic Cards
              I cringe when a customer tells me they need to run transparencies yet alone plastic cards! Any machine that is capable of doing plastic cards would be specialized and fusers designed for it.
              Best of luck
                Re: Plastic Cards
                I think he needs a special INKJET printer.
                • Synthohol
                  • 5806
                  Re: Plastic Cards
                  or just print on a card sized label sheet and stick them on the cards.
                  • D_L_P
                    Self Employed
                    • Oct 2009
                    • 1196
                    Re: Plastic Cards
                    Thanks in advanced.
                    I don't know of a KM printer but a good inkjet printer is the Epson ET-8500/8550 for under $600. The 11 x 17 model is ~$900. They take sublimation ink, min size of 2.2" x 3.4", and can handle 30 mil thick cards.
                    • Hishamawada
                      • 174
                      Re: Plastic Cards
                      Konica Minolta printable PVC sheet for card production /Digital printing sheet MKP-G1 - bettercardmaterial
                      Konica Minolta Laser Printable PVC Sheet Super White 0.3 Mm Thickness Suppliers and Factory China - Customized Products - Oases Technology
                      I have found this type of sheet and it is stated for printing in Konica Minolta laser printers .
                      Any idea about it ?
