DF-704 part
  • copierknob
    • Jul 2017
    • 70
    DF-704 part
    I called KM and they have be wing pay number. No baby find this in the service manual. It's a white roller with what looks like a mirror on the back. It's on the bottom of the ADF. When I open the ADF it's there on the underside.
  • Synthohol
    Certified Konica Expert
    • 5889
    do you mean the brush roller?
    you can just get the white label if thats what you meabt?
    • tsbservice
      Field tech
      • 8050
      See page 15, item 9 is white sheet for second side CIS brush roller.
      • copierknob
        • Jul 2017
        • 70
        Thanks. Just the white part is damaged from what I see. Now how do I get it out to replace the white sheet lol
        • copierknob
          • Jul 2017
          • 70
          Thank you.
          • Synthohol
            • 5889
            zoom in on the pics, timing it properly is paramount.
              • 23010
              Most of the time it can be cleaned. Are you sure it's damage? And yes, take care that it's timed correctly.
              • kingarthur
                • 1385
                I must've been very lucky, took one off of a C458 to replace one worn out on a C450i, just fitted it - forgot all about the timing, it appears to work fine
                • Synthohol
                  • 5889
                  i used to use white-out dots on gears and belts for timing like i did on cars long before copiers.
                  • copierknob
                    • Jul 2017
                    • 70
                    Yes, unfortunately it is damaged, as represented by the red circle. So is the CIS and mylar.
                    • copierknob
                      • Jul 2017
                      • 70
                      I don't know if it makes a difference. I am using a laptop and can zoom in on the picture I posted.
                      • copierknob
                        • Jul 2017
                        • 70
                        Good for you. How the heck did you get the old one off and the new one on? It's a whole sticker!
                        • kingarthur
                          • 1385
                          I moved the part it's on too - not just the sticker. The parts for that assembly, are the same for the C458 & C450i, luckily I had a scrap DF
                          • copierknob
                            • Jul 2017
                            • 70
                            That would have been much easier. After I finished it just grinds and gives errors C-6753 and 6755. Spent the whole day on it and did not resolve it
                              • 23010
                              This isn't going to help very much, but I offer it anyway. I took these photo before removing that roller from a DF-701. I certainly can't be certain, but I expect that that timing remains the same. These photos are very close, and blurry, because it's just really hard to see what you need to see. The simplest thing would be to look at another working DF, to gauge the timing.
                              If I was in your situation I would jump the belt one tooth, then try it. If it errors, jump the belt one more tooth, and try it ... etc, etc. It might only take 30 or 40 attempts. =^..^=
