I called KM and they have be wing pay number. No baby find this in the service manual. It's a white roller with what looks like a mirror on the back. It's on the bottom of the ADF. When I open the ADF it's there on the underside.
DF-704 part
Tags: None
do you mean the brush roller?
you can just get the white label if thats what you meabt?
rollerr.jpgAttached FilesWe know a thing or two because we've seen a thing or two.
The medication helps though...👍 2 -
See page 15, item 9 is white sheet for second side CIS brush roller.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.👍 1Comment
zoom in on the pics, timing it properly is paramount.Attached FilesWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Most of the time it can be cleaned. Are you sure it's damage? And yes, take care that it's timed correctly.If you'd like a serious answer to your request:
Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...👍 1Comment
Tip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
That would have been much easier. After I finished it just grinds and gives errors C-6753 and 6755. Spent the whole day on it and did not resolve itComment
This isn't going to help very much, but I offer it anyway. I took these photo before removing that roller from a DF-701. I certainly can't be certain, but I expect that that timing remains the same. These photos are very close, and blurry, because it's just really hard to see what you need to see. The simplest thing would be to look at another working DF, to gauge the timing.
If I was in your situation I would jump the belt one tooth, then try it. If it errors, jump the belt one more tooth, and try it ... etc, etc. It might only take 30 or 40 attempts. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 2Comment
