clutches failure
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    clutches failure
    Hello colleagues, do you know of any product to clean the clutches? Here in Spain there was a chemical company that manufactured a very good one and closed, and now I have not found a suitable one.
    Above all it is useful to test a clutch suspected to be failing without having to replace it to check it, or to clean others that are very difficult to access.
    Field technician since 1994
  • tsbservice
    Field tech
    • 8020
    Which product you used to clean/spray clutches?
    I would assume cleaning aerosol for electronics will do some job.
    • Hansoon
      • Sep 2007
      • 3388
      Blow them out with air, soak them with brake cleaner, blow them out again with air.
      Hans
      โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
      • elmaligno
        • Oct 2009
        • 302
        Belius-22
        • copyman
          Owner / Technician
          • Sep 2005
          • 4712
          I spray clutches with CRC Electronic Cleaner then blow out with air. I don't even remove clutches from machine. Put a paper towel or rag under clutch, spray clutch, blow off with air, remove paper towel / rag , done!
            • 23009
            In my humble opinion, by the time they're throwing rust dust it's too late to clean anything. It's time for new clutches, and usually all the clutches in that pack. It makes no sense to remove a drive pack, replace one very worn clutch, and leave four mostly worn clutches.
            Back when they were greasable clutches, cleaning and greasing sometimes helped. But with electromagnetic clutches, no. The last time I cleaned electromagnetic clutches on a KM-8003i I was carrying 3 clutches but needed 5. It was only desperation that made me completely disassemble all 5 of the old clutches, and scavenge enough parts to repair two of them.
            • Madnhain
              • Dec 2012
              • 148
              In my old age and laziness, I just replace the whole dang assy if available.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                The only clutch I don't clean and always replace is the exit clutch. This is the only one I ever see with rust.
                I use the electronic cleaner only on mag clutches. Just had a service call yesterday on an old Biz 223 that was printing half pages intermittently. Sprayed the reg clutch with electronic cleaner and canned air and out the door in 10 mins!
                • wjurls
                  • Feb 2017
                  • 498
                  This!!! Just replace the damn things. Yes, it can be expensive on a big PFU unit but I just had to replace a twice blown PF-706 board (ICP6) due to shorting out clutches. Konica priced the "paper feed clutches" a lot cheaper than the regular "clutch 1" part because there are so many of them in a PFU.
                  • Max
                    • Oct 2011
                    • 560
                    Solvent cleaner does a good job.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4712
                      It's easy to say just replace the damn things when you work for a company and not your money but when you are an Independent you do what you can to save the customer and you money. Especially if cleaning the clutch works just as good.
                      • tsbservice
                        Field tech
                        • 8020
                        Production and office machines are totally different animals. Downtime on production will cost a fortune compared to office machine. So you're both right ๐Ÿ‘ ... probably
                        I think nobody knows half what BC knows I'm with him on this one.
                        • wjurls
                          • Feb 2017
                          • 498
                          I am an independent. I ends up costing far more to replace blown boards and in return trips.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4712
                            Never blew a board because of a bad clutch or have return trips. My system is working and will continue to spray clutches. If I thought for 1 second it would cause issues I would just replace the clutches. But after 40 years of spraying mag clutches with elec cleaner and working great why change. If you are ok with spending $30 to $50 for a clutch go for it.
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4712
                              Just to be clear like I mentioned in previous post if clutch is throwing rust I replace them but I have taken apart and cleaned CL8 a few times when on 30-03 calls far away from shop and didn't have a new clutch with me. (probably going to regret saying this but still working good more than a year later). C454e & C554e, customer runs about 10k month on each machine.
