3070L and 3080P scattering toner
  • nullskull
    Learning
    • Aug 2023
    • 485
    Both the 3070L and 3080P I work on have varying degrees of toner scatter from the transfer belt cleaning module. What should I check in order to fix this issue?
  • Synthohol
    Certified Konica Expert
    • 5905
    this may help.
    foam.pdf
      • 23010
      Letting developers to run 150% or more of yield can do that. So can aftermarket toner.
