C224e Boot probleme
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    Re: C224e Boot probleme
    what i meant was the fixes and the file names to compare, like the individual versions ie:
    MFP Controller Print Controller AA6R0Y0-3000-GCF-W4
    if its the same as one in special FW at least that those bug fixes have been applied to that file.
    there are plenty of "hidden" fixes too but the file version will only go up alphanumerically if something new was added.
    i probably am not explaining my methodology or just off my rocker. either way you can see if the firmware file is newer than the last one.
    i do remember being told that every special firmware periodic release has all the bug fixes since the last release and more.
    • Gift
      • Mar 2011
      • 2459
      Got this from Brix some time ago (long time no see ) - it's referring to Cxx8 Series IIRC but I guess the naming scheme is the same:
      Base Versions:
      -G00/G20
      Base Version + new Fixes that will be included in future Base versions (kind of Beta FW):
      - GC/GQ/GE/GF/GG/GH
      Special FW made for certain customers/fixes that will not migrated into future base FW:
      - GP/GQ/GR/GS/GT/GU/GW/GX/GY/GZ
      @Topic:
      Firmaware - after installing a new SSD board on to a corrupted MFP board you must boot the machine with the reset tool, otherwise the new SSD board might load the corrupted data from MFP board and you can start from the beginning. Plus check the battery voltage.....
      • REGSIS
        • May 2016
        • 435
        I got a call today for C224e with trouble code FA14 after trouble reset it shoved D010.
        Note: 2 months ago this machine was struck by lightning resulting in dead network port, but USB worked fine until today.
        HDD state showed capacity of 470 MB with a vacant area of 0 MB - strange. I tried logical format with no result at all.
        Reboot machine (FA14 again) disabled HDD - UNSET (thinking that's the cause of problem) and OFF/ON.
        Machine stuck at two pillars and reboot after minute or two.
        KM advised me to try with FW or reset tool although FW might not start at all because HDD is turned OFF (I think HDD is mandatory for caching FW in process of rewriting)
        I cannot enter service mode to SET HDD back ON.
        New MFB board (and SSD) will apparently solve the problem (but that's the price of good used machine).
        Does anyone have any suggestion what to try to be sure what was cause of problem?
        Suspected parts (for now)
        MFP board
        SSD board
        HDD
        • Kenny
          • Jun 2009
          • 526
          #19
          MFP board
          SSD board
          HDD
          I Had the exact same issue but on a C454e, once i replaced the HDD and updated firmware was fine again. Before the FA14 code popped up the machine would take forever to select for example the utility tab, crash then pop up with the error code.
          Good luck
          • tsbservice
            Field tech
            • 8013
            #20
            MFP board
            SSD board
            HDD
            I think HDD cannot prevent machine from bootup and cause rebooting loop. SSD can.
            Can you get to the trouble reset screen?
            • REGSIS
              • May 2016
              • 435
              #21
              No! And i can't go back into service mode either.
              I could before i turned off HDD. When I turned it off (like many other times before on this kind of machine) and reboot machine couldn't start.
              SSD is not "broken" maybe corrupted by bad MFP board, because when HDD is turned OFF after reboot that change needs to be written and if MFP board is malfunctioned (as I suspected) it couldn't be done properly.
              If only HDD is the problem it could be UNSET and machine could continue to work without it but with limited capacity. Done this many times until I get new HDD to replace.
              Many times bad HDD could be formatted but in operation mode show D010 or D011. MFP board always showed 256 GB capacity. This one was reporting only 470 MB. That was very strange.
              I was in a hurry and I didn't run internal test first, assuming it is a HDD problem in the first place. My bad.
              • tsbservice
                Field tech
                • 8013
                #22
                Indeed that's strange. Is it sitting at two pillars forever or reboot after a while? Is the HDD physically removed?disconnected?
                P.S.
                SSDB is way cheap than MFPB I just hope the best for You
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4700
                  #23
                  I came across this on Kon/Min dealer portal pertaining to Firmware (see attached).
                  • REGSIS
                    • May 2016
                    • 435
                    #24
                    P.S.
                    Finaly, I made another visit.
                    First I tried FW update but it wouldn't start.
                    Then I tried with reset tool, and after a while I get a message. Data initialization successful.
                    Acvording to procedure it shoul show the code C-D390 followed by 2 reboot, and data backup option.
                    But machine keeps rebooting in 2 min intervals over and over again.
                    Even after OFF/ON it kept doing the same thing.
                    KM service support suggested new MFP and SSD board.
                    But I'm afraid if SSD is bad or corrupted, how can I restore data from old one to a new MFP board, which is a must do step as I'm been told by KM!?
                    • Gift
                      • Mar 2011
                      • 2459
                      #25
                      what's the battery voltage?
                        • 8144
                        #26
                        Try the SSD update tool you might be lucky.
                        Usually when the SSD is faulty the machine will continually reboot after just a few seconds, but if yours is doing it every 2 mins not the same fault.
                        • tsbservice
                          Field tech
                          • 8013
                          #27
                          I'm sorry but I would replace SSDB and then go from there.
                          • romario
                            • Jun 2020
                            • 192
                            #28
                            Originally posted by Firmaware
                            Hallo folks,
                            We have problems with a C224e. The Firmware was G20-M0 and original error was C-E302 by Scan to SMB. Printing', Copying .Scan to box. Scan to Usb-Stick: all ok.
                            I went to xustomer site and my first idea was FW- upgrade. Great Bad idea. I wonna upgrade with GDR-M1 and by MFP-controller upgrade the result was N.G.. Since that, obviously boot not more. 2 /4 Columns.
                            I'be tried an other HDD and with reset tool, but I've not the right one.
                            What would you do...
                            Thks in advance for your help
                            Gesendet von meinem SM-G980F mit Tapatalk
                            I have solved several machines with these problems, from series 4 to series 8, the first thing I do is turn on the machine with the yellow reset key, I enter service mode, initialize data, turn off and turn on the machine, it gives me an original error and I go back to load base firmware, and it is solved, try to see if you are lucky
                            thanks
                            • REGSIS
                              • May 2016
                              • 435
                              #29
                              Since only one board could be replaced at once and MFP is definetly bad (network LEDs are constantly ON without network cable plugged in) I suspect that MFP board couldn't write anything or can write but corrupt the data in SSD board.
                              Since I changed the HDD settings in service mode machine reboots. With that change bad MFP board might corrupt data on good SSD board.
                              With bad MFP board there is no point to change SSD board. Data backup couldn't be done.
                              If I put a new MFP board and data couldn't be restored from old SSD, then procedure couldn't be completed and I must send MFP board to Japan (and back) which is a 2 months wait (unacceptable for customes) and still without a solution.
                              • Firmaware
                                • 30
                                #30
                                It was the Ssd. I've replaced the Ssd and then I've upgraded the Firmaware. Thanks all
