Konica c554e.
  • TSS
    • Jul 2018
    • 32
    Konica c554e.
    When printing, the prints come out great,but copying on glass or adf they have a grey back ground.
  • Synthohol
    Certified Konica Expert
    • 5842
    even after removing the glass and cleaning the mirrors? cleaning the white strips?
    i'd do a background data reset and stabilize then all the gradation adjustments (3 each)
    • AlaskaCopyTech
      • Jan 2024
      • 78
      Run a preview on the screen (this can be set to a registered hard key if not present) and see if what shows up on the screen. If you have a black background you know it's something with the scanner.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4712
        You didn't say if you removed the glass and cleaned the optics? You should start there and do the gradation adj as Syn suggested.
        • TSS
          • Jul 2018
          • 32
          I did clean the optics.The rear mirror under scan lamp had some movement.Sometimes the copies are good and then hazy grey background appears.I am thinking the mirror in the scanner area is moving.
            • 23009
            Would you like to attach a sample?
            • TSS
              • Jul 2018
              • 32
              This gallery has 1 photos.
              • TSS
                • Jul 2018
                • 32
                This is the background when copying or adf.Prints are clear.
                • Synthohol
                  • 5842
                  lift the front left corner of the scanner bed with 10-20 lbs of force and make another copy.
                  this looks like a sunken/bent scanner bed to me on first glance.
