C360 JAMMING DF 617
  • JC Andres
    • Dec 2023
    • 40
    [Jamming] C360 JAMMING DF 617
    Hello people i am from mexico we have a lot of KM C360 and series 4 and 8, can you help me with this problem, i tried 3 adf 617 in two C360 and the 3 have the code 66-06 ONLY with the sheet 8 1/2 X 14 that its legal or officio in Mexico, buth in 8 1/2 x 11 its fine, i cleaned all the sensors rollers and all but still jamming, i check the motors and fine only the motor in the exit paper still in on after doesnt have any paper in the tray lift for almost 2 sec or 3, thank yall
  • Synthohol
    Certified Konica Expert
    • 5891
    J66-06 or C66-06?
      • 23010
      It's got to be a J66-06.
      That's caused by PS9. Often paper dust or paper punch holes fall onto the black felt sensor background, so you get false readings. Just pull down the guide left of the white plate and blow out the sensor and black felt with blower brush and toothbrush. Once it's clean, make sure that the black felt is still black. if not, darken it with a Sharpie marker.
      This is a common issue on almost every Konica Minolta document feeder.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4756
        Yep. Used to have a lot of calls on that style feeder because of paper dust on black felt pads.
