Konica c224 e can't access service mode
  • Tabasco
    • Aug 2025
    • 4
    #751
    Originally posted by jotunn
    Reset code for your machine:
    MFP Serial Number AAJP021245421
    Reset Code WGMND-TS4RC-6AA35-YCPV3-Q7DHH-CG8YD-ENJQH-AYTPN
    After entering reset code, machine should go directly to CE mode, and your passwords (CE and administrator) should be reset to factory default.
    Regards
    Thank you very much, the code worked perfectly. Both the Admin and CE passwords are now back to their default values, and I was able to successfully reset the device to factory settings. I truly appreciate your support. I had already sent you the payment in advance. I can only recommend your service!
    • jotunn
      • 632
      #752
      Glad the code worked and you reset the device! Thanks for the payment and kind words. Hit me up if you need help again!
      Regards
      • Quagbih2011
        • Jan 2025
        • 13
        #753
        Hey, I have after format my MFP and don't know the CE Admin password. Can you help me to reset it?
        Serial: ADXE021000194
        MAC:00:50:AA:53:A3:BF
        CE Passwort Request: HS4SW-RPCQ8-5GAJX-JPP8H-CS32H-9G8YD-ẸNQH-AYTDL
        • a7mad-989
          • Aug 2025
          • 16
          #754
          my friend Jotunn
          I want to thank you sincerely from the bottom of my heart for your patience and help.
          I would like to send you something through PayPal, and I’d like to know how much I should send.
