Konica c224 e can't access service mode
  • jotunn
    • 618
    #631
    Originally posted by jajcarzmaciek
    Hi
    Can you help me reset the CE password of Bizhub c454e ?
    THANK YOU VERY MUCH !!!
    Hello,
    reset code for your machine and payment link below.
    MFP Serial Number A5C4021102752
    Reset Code ZUC28-B5BEH-UCE7L-TNM98-E8PFV-2G8YD-ENJQG-MZDH5
    Regards​
    • Rase
      • Mar 2025
      • 3
      #632
      Hello, I am new at this forum... can anybody help me with admin code reset for my CM C224e?
      SERIAL: A5C4021001168
      MAC: 00:20:6B:89:F5:FF
      CE pass. res. request code: 59WTJ-J8BBL-SAK5H-RBDGF-86YMC-GG8YD-ENJQG-MZDJT
      • AKUGLOBA
        • Mar 2025
        • 2
        #633
        After payment what next?
        • jotunn
          • 618
          #634
          Hello,
          something's wrong with tthe data you've posted - please check once again for typos.
          Regards
          • jotunn
            • 618
            #635
            Instructions in the attachment.
            • Rase
              • Mar 2025
              • 3
              #636
              I fixed the password issue with USB from maintenance port with TAR file... thanks
              • Rase
                • Mar 2025
                • 3
                #637
                Originally posted by jotunn
                Hello,
                Regards
                • evlemp
                  • Feb 2025
                  • 3
                  #638
                  Hi jotunn
                  Kindly, may you help me with 2 CE passwords resets?
                  S/N: A79K011010771
                  MAC ADDRESS: 00:20:6B:BA:93:5F
                  CE PASSWORD RESET REQUEST CODE: FCSUS-U5BV2-35KUJ-5TBRV-LDA8E-2G8YD-ENJQG-8YTTX
                  S/N: A2X0017007720
                  MAC ADDRESS: 00:20:6B:9F:A9:7E
                  CE PASSWORD RESET REQUEST CODE: S24PK-V33D3-GWNMR-U3367-T24RU-6G8YD-ENJQG-MZDDJ
                  thank you in advanced, will be happy to paypal you!
                  kind regards,
                  • jotunn
                    • 618
                    #639
                    Originally posted by evlemp
                    Hi jotunn
                    kind regards,
                    Hello,
                    your request codes were little outdated, but reset codes should work. In case of trouble, please prepare fresh requests.
                    MFP Serial Number A79K011010771
                    Reset Code 9U64G-LVRJV-4PTTJ-JNJYE-TQAQ4-KG8YD-ENJQG-8ZDB5
                    MFP Serial Number A2X0017007720
                    Reset Code XURML-4CEJL-K4AX6-74EGW-884UF-KG8YD-ENJQG-MZDDX
                    Regards
                    • evlemp
                      • Feb 2025
                      • 3
                      #640
                      Hello,
                      Regards
                      Hi thank you for the quick response!
                      You are correct the code didnt work, i have access to only one machine at the moment so i will give that one a shot. Here is the most recent request code:
                      s/n: A79k011010771
                      request code: BS8U9-79LCL-CDBN8–EVUMB-7HXEH-9G8YD-ENJQG-MZDP7
                      Thank you!
                      • jotunn
                        • 618
                        #641
                        Thank you!
                        New code:
                        Reset Code XFEFB-PRVJX-TK98Z-5NMG4-FD3L9-9G8YD-ENJQG-MZDRN
                        Regards
                        • evlemp
                          • Feb 2025
                          • 3
                          #642
                          New code:
                          Regards
                          Youre the man! Thanks so much this code worked, got to the second machine today, inputted the reset code and it worked!
                          Thank you much appreciated!
                          • pmgno
                            • Mar 2025
                            • 6
                            #643
                            Hello,
                            I have a Bizhub C227 that won't go into sleep mode.
                            I wanted to reset the printer to factory settings, but the default password doesn't work. Can someone give me a reset code?
                            Thank you very much!
                            Printer Serial Number A798021012141
                            MAC-Adresse 00:20:6B:AD:93:72
                            Request Code 8A6FW-U6MPY-PZ4TE-BSTEZ-P46J7-SG8YD-ENJQG-MZTBB
                            • Synthohol
                              Certified Konica Expert
                              • 5846
                              #644
                              you are fortunate to have a bizhub that wont go to sleep, it will be more reliable
                              • pmgno
                                • Mar 2025
                                • 6
                                #645
                                You're probably right. 😅
                                I'd still like to know why it doesn't go into sleep mode, even though the timer is set to do so. At least the power consumption in energy-saving mode remains at 20-30W. Since the printer rarely runs, waking up for a longer time isn't a problem. I'm also interested in the CE password, of course. I don't have it because I bought the printer used.
